586,655 active members*
3,343 visitors online*
Thread: Bobcad issue
Results 1 to 8 of 8
    Mar 2014
    26
    Bobcad issue
    Need some help please. I am trying to figure out how to mill out the area between the 2 brown lines in the enclosed picture. I have tried evereything I know how to do but haven't had any luck. I have tried the pocket feature but when I used this it wants to pocket out the center section which is a hub area that needs to be left. When I choose profile and have to choose left or right compensation it makes my tool path correct for one but then other side will be wrong. Thanks in advance for any information !!
    Dec 2011
    361
    Re: Bobcad issue
    bcnu,
    Can you attach a part file to be looked at. It is hard to say without looking at the selected geometry on the toolpath.
    Mar 2014
    26
    Re: Bobcad issue
    You can ignore the lines in the middle , we tried that to see if it would clean up the area we wanted to mill out the pocket in. The area between the outside green line and the inside brown line is what i need to mill out
    Dec 2011
    361
    Re: Bobcad issue
    bcnu,
    The issue is likely because your outer shape has gaps in it. This will prevent it from functioning correctly, as it won't notice the outer shape is water tight.
    Mar 2014
    26
    Re: Bobcad issue
    I will take a look at that and see if that is the issue and let you know. Thanks
    Jun 2008
    1838
    Re: Bobcad issue
    Not sure if this is right, is the area shown on the image what you are looking to mill out ? ?
    Attachment 355990
    If so then it was some of the geometry appeared to have double entities which when cleared away allowed the outer dotted circle and the inner shape to be selected and allowed the toolpath shown using a 0.75mm cutter on a small 10% stepover.
    If not then let us know which area it is
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Mar 2014
    26
    Re: Bobcad issue
    SeanDa, that was the problem. Thanks for your help!!
    Mar 2014
    26
    Re: Bobcad issue
    Thanks for your reply Engine Guy, SeanDa's reply was exactly what the problem was.
  1. posting with bobcad issue
    By FUBAR62172 in forum BobCad Post Processors
    Last Post: 12-11-2016, 07:36 PM
  2. V24 BobCad issue
    By banjo_art in forum BobCad-Cam
    Last Post: 02-20-2016, 06:00 PM
  3. BobCad V23 Posting Issue?
    By Magnetboy in forum BobCad Post Processors
    Last Post: 05-28-2014, 05:59 AM
  4. BobCad V25 - Printer issue
    By older_pup in forum BobCad-Cam
    Last Post: 08-20-2013, 04:55 AM
  5. BobCad v22 Post issue.
    By smurph in forum BobCad-Cam
    Last Post: 11-19-2007, 09:00 PM
