586,540 active members*
2,933 visitors online*
Results 1 to 3 of 3
    Mar 2017
    3
    RDWorks language gibberish
    HI All,
    I just started using my NOVA 35 laser after many starts and stalls and have been having a great time. It works really well and I am very happy. However, something strange has just happened. I used the rotary attachment for the first time and success. But not that I am going back to regular "flat" lasering, RD Works is doing something weird, the language is all gibberish, nothing is in English anymore. I've shut everything down and started back up but its still gibberish. I have attached a screen shot of what's happening. Does anyone have a clue as to whythis is happening? and how to get back to English?
    Jun 2012
    91
    Re: RDWorks language gibberish
    Looks like a windows problem with the language code. What is your language/region set to? It has nothing to do with going from 2D to rotary... something else happened in between, I suspect..
    Uninstall, delete, reinstall after clearing out the registry of anything referencing RDWorks and see if the problem still exists.
    Nov 2017
    1
    Hello,
    My first post on this forum. Its been awhile since this question was asked and I hope it was sorted by now but if not then go to the top level menu bar and select the third menu item from the right (without the gibberish its usually the HELP button). navigate to the language selection sub menu and change back to English. I had this happen also and I could not figure out why the screen changed on its on accord.
    Regards,
  1. new 80watt - won't engrave in RDworks v8
    By mskaggs67 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-20-2017, 11:06 AM
  2. RDWORKS V8 Question
    By trrubicon06 in forum Laser Control Software
    Last Post: 12-25-2016, 06:35 AM
  3. Changing labels into RDworks
    By otromar in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-19-2016, 02:46 PM
  4. RDWorks and AutoCad 2017
    By snag96 in forum Laser Control Software
    Last Post: 07-12-2016, 08:35 PM
