586,983 active members*
3,703 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > CNC my mini mill using 3d printed parts
Results 1 to 9 of 9
    Jul 2003
    276
    I am hoping to get my Harbor Freight mini mill converted and able to cut replacement parts for itself using 3d printed parts.
    I purchased ball screws, 479 oz dual shaft steppers, etc just can't see dropping the cash for the Fusion kit :-)
    Been a long time since I posted on here joined in July 2003!
    Jul 2003
    276
    Re: CNC my mini mill using 3d printed parts
    Here is the Y axis mount and spacer based on Hoss machine cnc conversion
    Attached Thumbnails Attached Thumbnails Y Axis 1.jpg   Y Axis 2.jpg   Y Axis spacer.jpg
    Apr 2013
    1899
    Plastic is not really ideal for those parts, especially not the printed sort. Anyway, those two parts are pretty easy to make out of aluminium, why did you chose for printing? Must have taken forever to print those large parts.
    Dec 2013
    290
    He said his plan is to get it running, so it can machine its own replacement parts. Hard to CNC brackets without a CNC machine. And to manually machine them requires more tooling than if you were to CNC them.
    Looks like your printer is dialed in pretty well, nice smooth prints.
    Work: Hurco VMX42/VMX50 - Shopsabre 4896 - Bobcad V4 4axis pro
    Home: RF45 with Ajax CNC Controller - Bobcad V27 3 axis pro
    Apr 2004
    733
    Wish I had a 3d printer back 10years ago. I made my initial conversion parts out of plywood. Once I got it working good enough, I had the machine make them out of aluminum. You have to start somewhere and having nice 3d printed parts like yours sure makes it much easier.
    Jul 2003
    276
    Will have to post pictures of my printer. The thicker y axis piece is 20.4mm thick and took about 3 hours . Started with a prusa i3 before I modified it with open build extrusions
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Jul 2003
    276
    When my mill conversion is complete I will remake the 3d printed parts I have designed and printed for my printer
    Nov 2009
    4415
    Understanding your initial objective you have done well. The parts built should serve their purpose if loads are kept in mind.
    We all saw Hoss build quite a few prototypes with 3D printed parts (after I harassed him into using a 3d printer). They worked well enough for proof of concept.
    A lazy man does it twice.
    Jul 2003
    276
    Anyone going to the Midwest RepRap festival in Goshen IN this weekend?
    https://www.eventbrite.com/e/2017-mi...ts-28382784673
  1. Production of printed parts
    By ningbocctv in forum 3D Printer / 3D Scanner Discussion
    Last Post: 12-08-2016, 09:23 PM
  2. 3D printed parts for CNC?
    By crimar in forum 3D Printer / 3D Scanner Discussion
    Last Post: 03-02-2014, 09:39 AM
  3. Need parts printed?
    By eaglezsoar in forum 3D Printer / 3D Scanner Discussion
    Last Post: 11-12-2012, 09:58 PM
  4. where to get parts for mini mill in Aus
    By brendan_h in forum Australia, New Zealand Club House
    Last Post: 09-25-2009, 12:49 PM
  5. Mini Mill to make camera parts
    By Moesian in forum Benchtop Machines
    Last Post: 04-17-2005, 04:40 PM
