Re: v-29
I think the assumed behavior of a Machine Setup change is to reposition a clamp or otherwise stop the machine to jog away. At the very next feature, BobCAD returns to the position it was in before the Machine Setup change - then moves to the next feature. With my post I can see that the last XY value before the Machine Setup change was at X4.3527 Y5.1874 That's exactly where the tool is returning to after Block 16 (machine setup change) is called in the post.
In short, I believe this is expected behavior but I wouldn't mind hearing some input from other users. I don't use multiple Machine Setups very often.
Mastercam X9/2017 Multiaxis for SolidWorks - Bobcad V29 3ax Pro 4ax Std.
