586,801 active members*
6,424 visitors online*
    Jun 2004
    26
    Confused...Memory Used?
    I hope this isnt a dumb question.. I recently had to reinstall all the system parameters. Since then Ive noticed that the program Lib shows that I have 122940 used and 3780 free yet I dont have a single program uploaded yet. Whats going on?
    edit :Oh btw this is a 0M
    Feb 2007
    38
    Probably need to clear program memory. Hold just the DELETE key while powering up.
    If this doesn't work then you memory option parameter may not be set right since you just reloaded parameters.
    Final theory could be the SRAM chips on the memory pcb (if its a 0MC or 0MD) or the memory pcb itself. Hope my first post helps!
  1. confused???
    By johnm99 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-16-2006, 11:35 PM
  2. A Little Confused??
    By BuckingFastards in forum DIY CNC Router Table Machines
    Last Post: 02-09-2006, 12:20 AM
  3. Oh my God, I am so confused!
    By BlueMonster in forum Uncategorised MetalWorking Machines
    Last Post: 04-24-2005, 06:32 PM
  4. A little confused
    By Cold Fusion in forum Uncategorised CAM Discussion
    Last Post: 01-02-2004, 04:00 PM
