586,798 active members*
3,344 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > G130/G131 = no effect whatsoever
Results 1 to 9 of 9
    Jun 2008
    113
    G130=Super NURBS on
    G131=Super NURBS off
    I am in the process of implementing SuperNURBS into our Okuma's post processor, but to my big surprise, I can't make the control react to G130 or G131 commands at all. I've tried G131 with all the F/I/J/D... parameters but nothing ever happens. The only way to activate or deactivate Super-NURBS is through the menu.
    What is going on? The control is P200M
    Jun 2015
    4156
    Re: G130/G131 = no effect whatsoever
    on 131
    off 130
    "on/off" from code requires "off" from parameters ; thus disable function in parameters before running the code
    What is going on?
    where ? there ?
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Jun 2008
    113
    Quote Originally Posted by deadlykitten View Post
    on 131
    off 130
    Oops, of course. Thanks for correcting.
    No effect...
    Edit: It says in OSP-P200M manual that SuperNurbs should be switched off on reset or M2/program end, but on this machine it stays on until set off through the menu. The machine is MB-66VBE. Is there some undocumented parameter that controls this behavior?
    Jun 2015
    4156
    disable in parameters
    power off / on
    check status in parameters : should still be disabled
    enable from code
    during program execution reset the control
    check the parameter ... if "on" than is not good
    however, to do this, you must 1st enable it from code : did you succed here ?
    Dec 2008
    3113
    Does your machine actually have that option ?
    It could be Hi2NC .... which uses a different G code
    for usage, check out this link (eMastercam)
    ( F, I, J, D) there are other addresses used.... checkout post #8
    Jun 2008
    113
    Yep.
    power off / on
    Aye.
    Yes it is.
    enable from code
    Fail. Tried G131, G131 J0 F20000, G131 J1 E0.02,... but it stays off.
    I really don't understand what is going on here. Anybody from Okuma?
    ]Does your machine actually have that option ?
    Jun 2015
    4156
    so only parameter setting will work ... when you asked for G codes i shared you the codes for osp300, but maybe you need other codes
    you don't have programer manual or functions manual for 200 ? after a rapid search i can tell that G131 should work 4 u, but i did not find arguments or examples for it
    did you tried the codes from the link shared by Superman ?
    local Okuma dealer ?
    Jul 2010
    287
    I believe HiNC (and its variants) HiCut Pro and SuperNurbs all use G130/131 and it depends on which one your machine has as to which turns on.
    you mention you tried the whole long line of code. Is it possible you could post said code for us to review. maybe there's something wrong in there you missed at first glance.
    Jun 2008
    372
    The line of code should look something like this
    G131 F10000. J2 E.03 D.01 I3 L5. R.3 K0
  1. G131 (software work pusher cycle)
    By jorgehrr in forum G-Code Programing
    Last Post: 04-06-2023, 12:30 PM
  2. 1325 LC from Weike came in Thursday with no instructions whatsoever and...
    By pannaus in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-12-2016, 05:56 PM
  3. M3 and M5 codes having no effect
    By JBPlastic in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2011, 12:15 AM
  4. Smoothing effect
    By bundysax in forum Mastercam
    Last Post: 03-13-2011, 12:34 AM
  5. What am I getting this effect?...
    By cnczoner in forum MetalWork Discussion
    Last Post: 02-02-2008, 06:31 AM
