586,756 active members*
7,992 visitors online*
    NCstudio Spindle Speed
    I am using NCstudio version 5.5.60 and cannot find a way to get the software to slow the spindle to less than 6000rpm. I can set a spindle speed of (say) 500rpm in a Gcode file and the NCstudio screen will display this when the file is run. I can also set a speed of 500rpm manually in the input box on the NCstudio screen and the software will accept it. In both cases the actual spindle speed is always 6000rpm. I cannot find anywhere in NCstudio to set a minimum spindle speed (there is a setting for maximum). I have searche dthe manual that I have and as many on-line links as I can find, but without success. Is a minimum speed of 6000rpm hard coded into NCstudio? Or is there a "hidden" way to change this? Help with this would be very much appreciated because I want to use an edge finder that requires a spindle speed of 500rpm.
    Jan 2007
    1795
    Re: NCstudio Spindle Speed
    no, it is not in ncstudio
    this card, the 4.5 the 5.4 or 5.6 using socalled multisegment method
    check your vfd manual and you going to find a section where you set in 7 different segments 0-400 in case if your spindle 400 hz
    the first segment if your spindle 400 hz, then the first segment set to 100
    but from here it is up to you if you set lower
    i can not guarantee if it were ok to set lower
    i made couple of trial and down to 35 hz likely 1800 rpm it worked for me
    but again i can not tell you do it..
    i am only describing where it is set..
    Sep 2019
    5
    Hello victorofga,
    I have changed something in the parameter setting and i don't know what i have changed because the spindle is moving very slowly now.
    can you please help me
    Jan 2007
    1795
    what vfd you using?
    find first the manual online
    go trough on manual and check you set possible and set it to factory default
    they can be safe
    long time I had a machine with sunfar vfd
    I experienced similar and this is what I did
    never could fix really, tough it worked..
    that inverter made rpm ""wobbling""
    asked help from factory but still didn't worked over 260 hZ
    regards
    viktor
  1. Replies: 0
    Last Post: 06-10-2016, 03:08 AM
  2. big problem with ncstudio v8 spindle
    By alamiyassine in forum Spindles / VFD
    Last Post: 01-09-2016, 05:49 PM
  3. NCStudio Speed Limits????
    By shearder in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2014, 12:43 PM
  4. Replies: 1
    Last Post: 08-02-2013, 10:07 PM
  5. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
