This is all you need, all the basic Parameter Settings are the same for all the 400Hz Spindles, just voltage and Amps that are different
Don't do a Reset unless you have to, sometimes doing this affects the order of how the Parameters get set
Huanyang Mactec54
PD000=0 for Parameter unlock ( 1 ) for Parameter Lock
PD001=0 (1 For Remote Control)
PD002=0 ( 1 For 0-10v Terminal Control or Remote Trim Pot Control )
( J1 Also Needs to be set for Terminal Control )
PD003=400
PD004=400
PD005=400
PD007=20
PD008=220 (120 If you have 120v VFD )
PD009=15
PD010=8
PD011=120 ( 100 Minimum Setting with Quality VFD, 120 is Safe)
PD13= 08 is for Factory reset, Only use this to set VFD to Factory Default Settings
PD014 Acceleration=12 ( Adjust to suit)
PD015 Deceleration=12 (Adjust to suit) gf
PD142= ( Motor Max Amps)
PD142=( 220vSet for your motor Amp Rating 2.2Kw Spindle 9 amp )
PD142=( 220VSet for your motor Amp Rating 1.5Kw Spindle 7 amp )
PD142=( 220v Set for your motor Amps Rating 800w Spindle 4 amps )
PD142=( 120v Set for your motor Amp Rating 800w Spindle 7 amp )
PD143=2 ( Motor Number of Poles)
PD144=3000 (Max Motor RPM) =3,000= (24,000)
PD70=0 ( This may need to be set to 1 if Control Voltage is 0-5v )ygfy&
PD72=400
PD73=120 ( 100 Minimum Setting )
Hello, i just receive and want to use my spindle that works with a similar VFD.
i am not sure to understand all that you say here...
just want to don't do failure
PD000 i can put the value to 1 after all other PDxxx setup to lock them and keep in security?
PD001 is to use the VFD onside controls?
PD002 i want to be sure : i will use a 0-10V PWM converter so i put it to 1 and i have to change the J1 (is it the jumper on the right of wires connexions?) in this case have i to put PD001 to 1 too? or if PD002 is in 1 status it is saying that i can use remote control too?
My spindle is a water cooled one, so i can use the 100 value to PD011 an PD073? or it is better to keep a minimum of 120?
i don't understand what value i have to put in PD142 setup? 220? or 7? my spindle is a 1.5kW and 220v type
For the PD143; how can i know number of pole? is it number of magnets? in rotor?
and the last one :
PD144 have to be setup to 3000 if my spindle max speed is 24000 RPM or i have to put 24000?
Thanks a lot, and sorry about my english, i'm from france and not know all technic words.
Have a good days !
