586,500 active members*
2,819 visitors online*
Results 1 to 20 of 25
    Nov 2016
    34
    Testing 2560 board
    Is there an FAQ link that any of you know that would show how to test the 2560 board of my 3D printer.
    Symptoms are the extruder stepper motor is not working. I replaced the stepper driver that did not fix the problem.
    I am stuck as I am not sure what or how to test the next potential culprit.
    Any hints or links would be much appreciated!
    Jun 2005
    1730
    Re: Testing 2560 board
    Try swapping driver and motor from another axis, if that does not work it is likely a bad controller or a loose cable from controller to driver
    Nov 2016
    34
    Yes I did do that and it worked.
    Then I replaced the stepper driver and it still did not work.
    I am now trying figure out do I need a new board or something else.
    Thank you
    Jun 2005
    1730
    Rover31,
    If you swapped driver and motor with another axis and it worked, it worked which way. You mean it worked meaning the Servo/Driver you wanted to test worked on another axis? OR the bad axis works fine with the swapped motor/driver?
    I am going to assume you swapped the motor/driver pair and they worked when attached to another axis.
    If that is the case start following the wires from the servo motor to the servo driver. Make sure nothing came loose, sometimes the plugs and get loose. Then follow the wires from the driver to the cnc controller. That is where the signals come from to tell the driver/motor pair what to do. Also check the voltage at the driver there is usually a power cable to each driver and see if you have the correct power.
    Russ
    Nov 2016
    34
    Sorry need to be more clear, let me back up,
    The extruder motor was not fully functioning, sometimes it would work most of the time it will not.
    I unplugged the extruder motor and plugged it into the x axis stepper driver. It worked!
    If I plugged the x axis motor into the extruder stepper driver it did not work.
    I then replaced the extruder stepper driver and that did not solve the problem.
    Something likely related but not repeatable is that sometimes when I turn the unit on it will not function, it will not move on any axis. Turn it off, walk away come back and it works fine.
    I am very suspicious of the board. Power to the drivers shows correct volts so I do think the power supply is ok, I could be wrong.
    So if there is a faq on test steps for the board or the power supply point me to them as I have searched for months and am not finding a step by step test method.
    Thanks again!
    Jun 2005
    1730
    Rover31,
    This sounds like the controller board is flaky and not working all the time. Since it does not work all the time when you turn this on this could be power regulators on the controller board. Need to see a picture but that would be my guess.
    Russ
    Nov 2016
    34
    I agree,
    How do I go about testing the power regulators? I am seeing several things online but was hoping to get pointed to a more focused test that pertains to 2560 boards.
    Thanks again!
    Jun 2005
    1730
    Post a picture of the controller board a close up view so you can see all the components on the board. You will need a VOM or volt meter to perform some tests on the power regulators. I can explain where to test when you post a picture.
    Russ
    Nov 2016
    34
    how is this view?
    Jun 2005
    1730
    Well the driver boards are clearly on the right side of the board. The regulators are actually underneath the ribbon cable. You see the aluminum heat sinks standing proud of the board just under the ribbon cable. The parts mounted on those aluminum finned heat sinks are the regulators. Take a close up picture of those and I can tell you what you can do to these them. Make sure the power is off when you are in there taking pictures and moving cables, you don't want to short anything out.
    RUss
    Nov 2016
    34
    How about this one?
    Jun 2005
    1730
    There appears to be three regulators one on each aluminum heat sink.
    Can you get a side shot or can you read the numbers on the first part, it should be printed on the black device and the device normally has three pins that are solder into the board.
    Russ
    Jun 2008
    128
    It looks like you have your extruder driver drv8825 board plugged in backwards.
    Nov 2016
    34
    Quote Originally Posted by george4657 View Post
    I did plug it in with the regulator in the same position, that is not correct?
    Nov 2016
    34
    like this pic does that help?
    Jun 2008
    128
    If you look at his page http://www.geeetech.com/wiki/index.php/GT2560
    You will see that the adjustment for current setting of the drv8825 is at the oppsite to a4988 drivers.
    Nov 2016
    34
    hmm I see said the blind man...
    That is a great page, lots of good info.
    Thank you for the pointer, I will report the results, that is if I have not fried something.
    I have in fact, looked at replacing my board with that very gt2560 board, it looks quite nice.
    Thank you
    Nov 2016
    34
    10 min later...
    Ok so unit is unplugged
    flip the driver over...
    plug in and power up...
    and ... no change, the extruder is not moving. All other axis function as they should.
    So I think, well maybe I fried the driver. I have another! So, depower and unplug. Remove the 1st replacement and install #2 (correctly!).
    And... nope it doesn't work either. This time the rest of the axis decide they don't want to play either. No movement, the motors are making noise like they want to move but are not.
    This is what it does to me with no warning.....
    ARGH! What is going on?
    oh Thank you again for taking the time to read and make suggestions
    Jun 2005
    1730
    Rover31,
    The part in the last picture is a STMicroelectronics P55NF06L, which is a 55 Amp Power MosFet. This part probably is used to provide the current to the heater in the extruder would be my guess. I can't see the writing on the other two parts that is probably the regulators. If you can get a small mirror and write down those part numbers I can find out. Since you reverse a driver on the control board you probably damaged something on the control board would be my guess. However, if this stopped working before you touched the inside and does the same behavior after you went inside you might not have caused the damage by reversing the board.
    Russ
    Jun 2005
    1730
    After looking at the website that George4657 posted the link to, the three parts with Aluminum heat sinks are all Power MosFets, one controls the current to the Hot Bed, Extruder Heater#1, Extruder#2
    None of these parts are voltage regulators. Most likely the regulators are not bad or the other stepper motors would never move.
    Russ
  1. Free Mach3 Breakout Board in Exchange For Field Testing Its Plug-in
    By frankee in forum Mach Wizards, Macros, & Addons
    Last Post: 03-16-2013, 10:12 PM
  2. ACC Board testing help...please
    By markhas in forum Bridgeport / Hardinge Mills
    Last Post: 10-10-2012, 07:13 PM
  3. Replies: 0
    Last Post: 03-08-2011, 12:28 PM
  4. 2560 error
    By guydrisc in forum Okuma
    Last Post: 05-11-2009, 03:01 PM
  5. testing board
    By Integrex in forum Hobbycnc (Products)
    Last Post: 11-06-2007, 06:55 AM
