586,531 active members*
2,926 visitors online*
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Jun 2005
    1730
    Re: Testing 2560 board
    The website also confirms if you plug in a driver board backward it will cause damage to the main board.
    A4988 should also be connected to the right port, mismatches and revered directions can cause damage to the main board.
    Russ
  2. #22
    Nov 2016
    34
    Russ
    Thank you very much for your time!
    I will be ordering a new board today.
    It is odd how this started and ended I am sure that I complecated it.
    Unless one of you experts chimes in I am going to order a gt2560 mega board. Especially given the excellent page posted earlier.
    Thank you and I will try to report back when fixed.
  3. #23
    Jun 2005
    1730
    Rover31,
    I am pretty sure that will fix your issue. It appears looking at the gt2560 board that the step and direction signals come directly from the MEGA cpu chip. Many designs these type signals are buffer through another chip but I do not see anything in the photos, so that is most likely your issue. Reversing the driver board probably sent the driver voltage back into the MEGA chip with burned those output transistors on those ports.
    Russ
  4. #24
    Nov 2015
    I know this is an old thread, but I believe that board won't allow the extruder motor to run if the hot end is below a certain temperature. Just a thought for anyone else who might be here looking for an answer. Make sure the hot end temp is at least 170 C before testing.
  5. #25
    Nov 2016
    34
    Thanks for bringing this back up I should have come and updated it!
    I could not figure out the problem but a great guy in the Seattle area did find and fix it.
    My original board had a blown fuse (why oh why did I not check that!?) and the steppers drivers that I purchased did not have the correct voltage rating so luckily I had an extra of the original ones. So on it went and the unit runs as it should now.
    So check your board out thoroughly before spending/buying a new one. My original board is totally fine!
    Thanks to all suggestions!!!
Page 2 of 2 12
  1. Free Mach3 Breakout Board in Exchange For Field Testing Its Plug-in
    By frankee in forum Mach Wizards, Macros, & Addons
    Last Post: 03-16-2013, 10:12 PM
  2. ACC Board testing help...please
    By markhas in forum Bridgeport / Hardinge Mills
    Last Post: 10-10-2012, 07:13 PM
  3. Replies: 0
    Last Post: 03-08-2011, 12:28 PM
  4. 2560 error
    By guydrisc in forum Okuma
    Last Post: 05-11-2009, 03:01 PM
  5. testing board
    By Integrex in forum Hobbycnc (Products)
    Last Post: 11-06-2007, 06:55 AM
