Tonight was the first time that I have attempted 3D milling on my IH mill. The piece below was cut from 2x2x1 aluminum using a 3/8" ball end mill held in a collet. Overall I am fairly pleased but I do see one problem. Namely, the flat area is 7 thou higher at the beginning than at the end. This creates an edge that is easily seen when holding the part in your hand and may be noticeable on the right side in the picture below. The end mill might have slipped though the cuts being made were very light. Might there be other reasons? Is it even reasonable to expect better from this mill? I have never measured any backlash in the X and Y but have measured (and attempted to correct in Mach3) .002 backlash in the Z. Though, I don't think this is a backlash problem. What else should I consider to try to isolate this error? Perhaps unrelated but I also often have an edge formed at the beginning/end of an outside contour.
