587,493 active members*
3,515 visitors online*
Results 1 to 7 of 7
Hybrid View
    Feb 2017
    32
    Just a question about macro
    I've done 4th axis, work offset macros, just curious if anyone has done dynamic work offset macro?
    Aug 2009
    684
    Quote Originally Posted by macroguy View Post
    Yes. There should be some threads on the site detailing the concepts.
    DP
    Feb 2017
    32
    Re: Just a question about macro
    Where to find them?
    Aug 2009
    684
    http://www.cnczone.com/forums/parametric-programing/146527-automatic-calculation-fixture-offsets.html
    Feb 2017
    32
    I've already got that I calculate against the set work offset. By dynamic I mean as the 4th axis is turning constantly updating the offset. I guess G54.2 does it so I'll dabble with that some time.
    Just curious if it can be done with a macro on a machine that doesn't have the option?
    Jan 2016
    13
    I've worked on a program to do this on a 4 axis vmc. It can be done but was not accurate for my needs. If my rotary and fixtures were more square to the machine I think I would of got better results. The problem is I work in an enviorment with other machinists where things get crashed fairly often.
    Feb 2017
    32
    Many years ago I worked at a place that I think did it, I never paid too much attention to it then, we entered work offset info in the macro instead of the work offset page.
  1. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  2. Complicated (for me) macro question
    By wouldja in forum Haas Mills
    Last Post: 10-31-2012, 09:48 PM
  3. G47 MACRO 599 QUESTION
    By panaceabea in forum Haas Mills
    Last Post: 04-09-2009, 10:27 PM
  4. Macro B Question
    By Bluetech in forum Fanuc
    Last Post: 03-10-2009, 06:58 AM
  5. 21i Macro Question
    By marcwdci in forum Fanuc
    Last Post: 03-11-2008, 08:04 PM
