587,056 active members*
3,522 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Thoughts on this spindle?
    Jan 2017
    14
    I don't have any experience with these chinese spindles on aliexpress so I was wondering if someone could give me their 2 cents. I'm in the process of building a steel/granite mill that will be used mainly for cutting aluminum but I would like to be able to take small passes on steel as well. I have a hitachi sensorless vector drive good for up to 4 hp. Do you guys think this spindle is up to the challenge?
    https://www.aliexpress.com/item/2-2k...308.0.0.Rav4IQ
    Jun 2005
    1730
    Re: Thoughts on this spindle?
    That would handle aluminum, but honestly the Chinese high speed spindles usually have a RPM range from 6000 to 24000. Cutting aluminum is fine with solid carbide endmills at higher spindle speeds, I normally use 9K. Cutting steel on the other hand is a different animal. Normally the spindle speed is much slower 2500 to 5000 and you need a table that support coolant flood.
    Russ
    Feb 2007
    711
    What's up with the air port on the bottom?
    Personally I would get rather get this spindle for almost 1/4 the price and just replace them as needed.
    ER20 2.2KW WATER-COOLED SPINDLE MOTOR ENGRAVING MILL GRIND CE FOUR BEARING CNC | eBay
  1. SPINDLE PURCHASE - Thoughts?
    By mussersail in forum Avid CNC
    Last Post: 07-20-2016, 07:05 PM
  2. High Speed Spindle Thoughts
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 06-26-2015, 03:50 PM
  3. Thoughts on my strange spindle design
    By jamesglanville in forum Hobby Discussion
    Last Post: 11-24-2013, 02:01 PM
  4. CNC to NC Thoughts
    By Fish4Fun in forum Open Source CNC Machine Designs
    Last Post: 03-24-2011, 06:11 PM
  5. New Spindle Thoughts
    By SPEEDRE in forum DIY CNC Router Table Machines
    Last Post: 01-05-2006, 07:25 PM
