586,655 active members*
2,896 visitors online*
Results 1 to 7 of 7
    Oct 2010
    121
    TL 2 Low battery voltage
    When i powered up our TL2 on friday i got a low battery voltage message in the bottom left corner before it froze on the white screen with the Haas logo. I have spoken to Haas who have quoted for a "service kit for battery board". Has anyone had any experience in this repair? I have done a bit of research and it seems i may lose all settings/progammes etc. Just wondered if its any easy repair or best left to Haas to fix it?
    Jul 2014
    22
    Re: TL 2 Low battery voltage
    Hi, this happened to my haas, had them come out and replace the battery. The original board has the battery soldered onto them which they replace with a battery carrier so in future you can change the battery, however when they replaced the battery the first time they damaged the motherboard, but replaced it free of charge. So if you want to take the chance and do it yourself you can, but I would just say pay the money they charge just incase it goes wrong! But yes if left too long with the warning light on you machine will lose all its parameters and unless you have them saved it will cost you a fortune!
    Oct 2010
    121
    how did they damage the motherboard?
    Oct 2010
    121
    its back up and running! I have to say the Haas guy was really good and talked me through the settings/params over the phone
    Jul 2014
    22
    They didn't know, said it could of been shorted when soldering on the new battery carrier
    Oct 2010
    121
    didnt have to solder our one, they now supply it with a sticky pad Click image for larger version.
    Mar 2014
    133
    Be careful with the Velcro ones as well. There was an issue with those when they first came out.
  1. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  2. High voltage power supply, low voltage perihperals
    By feechl in forum CNC Machine Related Electronics
    Last Post: 01-07-2014, 02:12 AM
  3. Replies: 2
    Last Post: 11-07-2013, 04:34 AM
  4. Replies: 1
    Last Post: 10-03-2013, 07:48 PM
  5. Precix 9100 Controller - VI voltage issue Voltage range only 6.5 to 10Volts
    By wdysf150 in forum Controller & Computer Solutions
    Last Post: 08-15-2013, 08:24 PM
