586,792 active members*
2,687 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 Slow, Hangs, Freezes doing 40x20 pattern
    Jan 2013
    263
    Is a 40x20 pattern of a simple square really too much? I'm trying to model a vacuum table and my 40x20 pattern is absolutely destroying fusion 360. It runs great otherwise, but I turned down all the graphics settings regardless. Not surprisingly, didn't help. This is a sketch pattern. Using spacing, not extent.
    Jan 2013
    263
    Re: Fusion 360 Slow, Hangs, Freezes doing 40x20 pattern
    Patterning a 3D feature 40x20 times doesn't give me this issue.
    Sep 2009
    1856
    When you do patterns you pattern feature not sketch, Yes sketch patterns blow, pattern feature is fine
    http://danielscnc.webs.com/
    [SIGPIC][/SIGPIC]
    Feb 2009
    311
    Fusion certainly has a long way to go yet in terms of sketching performance. But even still, sketch patterns should only be used when absolutely necessary. Feature/component patterns are nearly always faster and easier to work with.
    C|
  1. g-code hangs
    By baldysm in forum Haas Mills
    Last Post: 10-08-2014, 01:32 AM
  2. Replies: 3
    Last Post: 08-08-2014, 04:42 AM
  3. Limit/Home wiring and how slow is slow?
    By Michaelofburien in forum DIY CNC Router Table Machines
    Last Post: 05-24-2013, 07:44 PM
  4. Slow response from CNC Fusion?
    By JWeb in forum Benchtop Machines
    Last Post: 11-06-2010, 08:40 PM
  5. Fadal 40x20 and FeatureCAM
    By j81hatala in forum Fadal
    Last Post: 09-22-2009, 11:22 PM
