586,847 active members*
2,477 visitors online*
IndustryArena Forum > CAM Software > MadCAM > Newest download of Madcam trial missing posts, tool library, machine library?
Results 1 to 20 of 33
    May 2006
    343
    As title says, am I just missing where to look? I purchased 4.3 Madcam, but trying the newer version.
    I installed it on my 64bit computer, I did download the 64bit Madcam version (completely new computer than my old setup) and I can't find the post processors, tool library or machine library.
    On my old setup they were there and worked perfectly.
    I'm trying to cut something tonight
    May 2006
    343
    Re: Newest download of Madcam trial missing posts, tool library, machine library?
    I Uninstaller it, reinstalled it... now when I click on cutter, cutter tab just flashes for an instant then disappears
    May 2013
    261
    It seems that every once ina blue moon new users have issues with posts not showing or tools or some other such ,
    Try down loading again , if that does not work look through some past threads Some of the more experienced users recently posted other fixes also, like where to go to load them.
    May 2006
    343
    I've tried 3 times uninstalling reinstalling. I have been right clicking on the file to delete. I didn't see an uninstall file.
    Is deleting the correct way to get rid of it and try again? Second time I tried it I tried it I also restarted computer
    Apr 2003
    1357
    The posts, cutters, etc. are located in C:\ProgramData\5XCNC\madCAM\5.0.
    By default the ProgramData folder is hidden, so you may want to make it visible.
    Also, when you first set up madCAM 5 you need to point it at this folder in the options. Take a look below (but ignore my locations. I set up a different location for defaults because I don't want mine overwritten with service releases).
    Attachment 346758
    It's been so long since I set up a default installation of madCAM without my customizations that I'm going from memory, but I believe you might find 3-axis, 4-axis etc. as the machine choices.
    Hope this is useful,
    Dan
    May 2006
    343
    How do I find that folder if iit's hidden ?
    May 2006
    343
    OK, found out how to find hidden files
    May 2006
    343
    All those folders are empty. And when I atleast point to one of those folders... I close box after trying to save... I reopen. Nothing. Have to start all over... which obviously gets me nowhere. This is Windows 10
    Mar 2004
    1661
    I've seen this problem before and it was a user rights problem. If you installed as a user, did you get a dialog to approve the installation as an admin? If not, try to right click the install exe and choose "Start as Admin" or whatever it says in Win 10.
    May 2006
    343
    I dont think it ever gave me that option. I guess I'll delete it and try again and see
    May 2006
    343
    Bought another laptop with Windows 7. Exact same thing. I just don't get this. All the folders are empty. I can't use the demo version at all
    Apr 2003
    1357
    Did you try downloading the install file again? Maybe your original download was incomplete.
    May 2006
    343
    This latest download was on a completely different computer.
    If you look in your ProgramData folders, you should be able to view what's in there... like the post processors?
    When I open the post processor folder nothing is in there. All of those folders that you need are completely empty for me
    Apr 2003
    1357
    Download this and add it to the 5XCNC folder. This is the original content that you are missing.
    https://1drv.ms/f/s!Ai1Xi4NSj31biPFvPLeqNfyd_feVzw
    May 2006
    343
    I'll try that in a couple of hours. Thank you
    May 2006
    343
    ok, so here's whats going on. I downloaded your file Dan. Everything is in there and looks good.
    When I open up settings tab in Madcam, go to machine tab... I try and grab post processor file, and it shows there's nothing in there. as soon as I click on where post should be, nothing shows up. if I open folder out of Madcam... (only in your downloaded file Dan) they are there.
    I even copied just the text post to put on desktop...knowing it's just searching for a .txt file... and it won't recognize it.
    there's something corrupt within Madcam that won't let program view it.
    and without having a post in there it won't allow me to save any of the settings so I have to start over every time I try and get this to work
    May 2006
    343
    Apr 2003
    1357
    If you look in the .mch files under the machines folder you will probably see the first four lines looking like this:
    Postprocessor
    Tool_Library
    The first time you set up madCAM 5 you need to associate posts and cutters with the machine you picked.
    This is how it is supposed to work:
    Pick the machine type from the panel on the lower right:
    Attachment 347812
    With the machine highlighted now go to the post processor browse button and find the folder and the txt file you want to use. Do the same for the cutters. Now go up to the top and save it. You should now see the .mch file containing something like this:
    Postprocessor
    C:\ProgramData\5XCNC\madCAM\5.0\Post Processors\A CNC3000.txt
    Tool_Library
    C:\ProgramData\5XCNC\madCAM\5.0\Cutters\Cutters_mm
    Axis_Mode
    If that doesn't work I would be willing to remote into your system using Team Viewer to see if I can make this work for you. If you want to do that we can move this discussion over to private e-mail.
    Let me know if this helps,
    Dan
    May 2006
    343
    Maybe this is why it hasn't been intuitive to me. Nothing has ever popped up in that box.
    May 2006
    343
    OK popup window was hiding screen you just showed me. But, still have problem with posts. They're in my computer, but Madcam can't see them when I go to it's location.
    I'd love to take you up on your offer Dan.
  1. Tool Library Set-up
    By Idiod in forum BobCad-Cam
    Last Post: 11-19-2015, 04:27 PM
  2. V24 Tool Library
    By Ben S in forum BobCad-Cam
    Last Post: 11-08-2013, 10:36 PM
  3. Tool library for download?
    By The Pininator in forum Uncategorised CAM Discussion
    Last Post: 06-30-2013, 02:12 PM
  4. V24 BobCad Tool Library Missing?
    By MicroMill in forum BobCad-Cam
    Last Post: 02-26-2013, 01:18 AM
  5. Tool Library
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-26-2011, 08:11 AM
