Ohhhh. I think I found the source of my right-left confusion: they were meant for lathes, and lathes cut from underneath the stock. I was looking at them from the viewpoint of a mill, thinking if the cutter turns clockwise, the carbide should be on the right. The carbide is on the left, for a lathe, but for milling, they held upside down, putting the carbide on the right.
I appreciate your help. I just don't want to get a box of assorted ones and experiment, or find that I have the wrong one, and I have to spend $5.00 to skip 1 $3.20 part. I will get spares.
I imagine the carbide chip issue would also affect these:
This one is nice an beefy, though.
http://www.newmantools.com/specials/b52.htm
This one is homemade (translated):
http://babelfish.altavista.com/babel...furaisu-17.htm
They do look strong. I read somewhere that, fly cutters often cut on both directions--even at the same depth, suggesting that the stock the carbide is mounted on may bend.
[This reminds me of a article about wood plane tear out. I've read the reason would tears out, is because the blade bend as it cuts, and snaps/whips back--tearing out the wood.]
