Re: servo motor testing / ohms resistance help
The normal resistance of that size of servo is a very low Ohm value across the leads, and open circuit or very high Resistance to frame.
You can test the motor to some limited degree with a automotive battery in either direction for rotation, also shorting the leads together and try and turn the motor shaft should offer resistance to turning, (braking effect)
In some cases carbon dust builds up and causes tracking to motor frame which can be a cause of ground connection.
Al.
Albert E.
