586,807 active members*
8,395 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Require your urgent Help PLASMA CAM LIFTER ERROR
    Dec 2016
    6
    Hi
    I have this Plasmacam machine with me. I'm facing this issue that when I starts the program, the torch is not coming down,
    The X and Y axes moves perfectly but the Z axis remains at the same height(at the initial position). Because of this I'm not
    able to use the machine for a long time. Recently found this site and thought to post my concern here.
    I hope someone will be able to help me in this topic.
    Jun 2008
    562
    Re: Require your urgent Help PLASMA CAM LIFTER ERROR
    I can't help you but you could also try here for help. Plasma Table Discussion Forums - PlasmaSpider.com
    Good Luck
    Mike
    Jan 2011
    188
    call plasmacam - does the axis move up and down with the buttons - does the software show the Z axis control features enabled - my z axis cable connectors have to really be pressed together hard whenever connecting them - once in a while I've had to reseat the Z axis connector -
    www.signtorch.com
    Dec 2016
    6
    Quote Originally Posted by SignTorch View Post
    hi,
    Thanks for your reply
    And yes using the buttons, while doing trial run in Manual mode, I'm able to move the lifter up and down. But when auto mode is ON,the Z axis never comes down.
    Sep 2014
    112
    Usually if there is a critical problem with the Z axis an error code appears on your computer screen within the plasmacam software. If you press the up and down arrows (on the right hand corner of the control) it should move the z axis up and down. There is also a lot of trouble shooting information within the plasmacam video manual that came with the machine. Plasmacams tech support or their online owners community can also be really helpful for you, as well.
  1. Vacuum Panel lifter
    By elking in forum WoodWorking Topics
    Last Post: 09-11-2015, 01:09 AM
  2. Torch Lifter Seal Band
    By jgramlich in forum Waterjet General Topics
    Last Post: 06-16-2015, 03:14 PM
  3. EMERGENCY - NEED HELP SOURCING UK SUPPLIER - URGENT URGENT URGENT
    By ApexLaser in forum Want To Buy...Need help!
    Last Post: 07-19-2014, 04:37 PM
  4. Replies: 3
    Last Post: 09-02-2010, 08:19 PM
  5. URGENT: 2J Quill return sping replacement -URGENT
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2006, 05:48 AM
