586,315 active members*
3,242 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > stepper driver frequency help .
    Sep 2005
    167
    hello
    i recently build alan picstep driver
    i set it up to 1.6amps and powerd it with 30volts
    i used a 1.6amp 2.7volt bipolar stepper.
    i didnt use a computer
    i just used a small pic 16F628A circuit that generated a pwm frequency to feed the step signal
    i tied the enable to ground .
    now the problem
    the max frequency i can feed to the driver before the motor stall is 18khz. then it stalls ( i tried it up to 20khz) (50% duty cycle)
    i tried changing the input voltage (lower it to 12V) but there were no effect on the motor speed at all, just a lower noise from the motor.
    the motor speed is not high at all, i estimate it to be about 200rpm or something like that.
    am i missing something here ?
    i know that the frequency can go much higher than that but the motors stops and make a hissing noise.
    i dont know if this is important or not but i replaced the 1uf capacitors on alan circuit with electro caps. ( i dont have any mkt on hand), also replaced the 2.2nf with 2.6nf
    i will appicate any help here
    thank you
    Jun 2003
    3312
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Sep 2005
    167
    thanks phil
    i sow the link
    and since i am using 30volts and 1.7amps and i am using bipolar motors not unipolar i can only think of using microstepping rather than full step
    i hope that will solve the speed problem
    Sep 2005
    167
    hi again phil
    well
    i just removed both jumpers on picstep board to switch to least microstepping
    and the speed was even lower !!
    now the max frequancy i can feed is about 2khz !!!
    i tried 1/4 1/2 steps
    but still the same problem
    what am i doing wrong !!!
    Sep 2005
    167
    i raised the voltage to 35volts, and the amps to about 1.9amp
    still the same
    any ideas please ??
    Jun 2003
    3312
    What kind of speed are you expecting? 18khz at full step would be 90 rps, and you're not going to get anything near that with a conventional driver. A lot of factors go into speed. 2K at full step is 10 rps which is pretty respectable.
  1. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
  2. Stepper-High Pitch/Frequency Noise
    By azt34 in forum Stepper Motors / Drives
    Last Post: 05-19-2006, 01:41 AM
  3. Stepper Driver
    By girandola in forum Stepper Motors / Drives
    Last Post: 02-17-2006, 05:12 PM
  4. Has anybody used this stepper driver?
    By phantomcow2 in forum Stepper Motors / Drives
    Last Post: 10-27-2005, 03:25 AM
  5. New Stepper Driver??
    By ViperTX in forum Stepper Motors / Drives
    Last Post: 08-05-2005, 12:46 AM
