586,807 active members*
7,971 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc motherboard repair company needed
Results 1 to 10 of 10
    Feb 2009
    23
    Hello all
    We need a fanuc repair company
    We hawe a motherboard and all the cards to send for repair
    Motherboard type
    A16B-1010-0210/16D
    Atachet in the board are
    I/O C3A A16B-1211-0300 A
    3RD/4TH AXES A16B-1211-0310 B
    PMC-M A16B-1210-0810 A
    GRAPHIC-MPG A16B-2110-0800 B
    Power sypply
    Can you help my find a good repair company for these types off boards
    Thanks to all in advance
    The problem with these board or its from outside is the problem
    We change the board from one machine to next machine before the boards works fine after change in both machines screen the crt is blank and no start off the both machines
    Oct 2006
    16
    Re: Fanuc motherboard repair company needed
    can you send them off to Fanuc, they generally service controls back to the 5M family and they do repair the 0 series.
    Feb 2009
    23
    Fanuc its to expensive
    Ay need a independet company with a test bed and repair capabilties
    If you now any company will by great
    Thanks in advance
    Apr 2009
    1379
    How much does Fanuc charge per hour and per day?
    Jun 2004
    511
    160 per hour around these parts. Sounds like OP is looking for in house PC board bench work. The likelihood of any non OEM having a test bed is slim to none. Look for an used replacement board, maybe E-Bay?
    Apr 2009
    1379
    "160 per hour around these parts." That is likely less in Eastern Europe.
    We can test the assembly up to a point; no drives/motors connected here. However, it is very likely that something (a spike?) in the machine is damaging the motherboard, so replacing it with another one won't solve anything.
    It's easy to spend a week on site for a problem like that, especially if intermittent. I would have to be paid in advance for time and expenses.
    Jun 2004
    511
    I did not read the original post clearly "after change in both machines screen the crt is blank and no start off the both machines" indeed shows that something in the machine is harming the motherboard.
    Apr 2009
    1379
    lol.
    Feb 2009
    23
    Hello to all
    Fanuc to us charges on site no parts involved is 160 euro per oure like 190 us dollars
    For the road trip from bulgaria sofia to macedonia in tetovo its round 300 kilometres and chargas 9 our included the time te riturn back to sofia 50euros in total 450euro for the trip plus the 60 euro for one hotel night
    These only to diagnose the problem
    Or mayby thel fix these only for one machine
    And the are companys from ukrain from canada and from us how can repair and test the board
    One more thing wat is non oem
    These is device or
    In oure machine we hawe the alarm 086 r/p inteface
    We hawe treyed cables parametre from 300 to 304 change the baut in pc 4800 and les evrithing
    Maybe was some problem in the board we left in the end
    In the board witch chip is responsibile
    Inone machine the memory it 12 time smaler the the 2 machines
    Witch chip its rispinsibile
    If we send to repair company can they change these
    Fix the dnc problem and the small memory
    Best to you all god bless you and your love ones
    Apr 2009
    1379
    Our rate is USD100/hour + expenses. The issue is the limited time available before Christmas, so if I were to go, it has to be decided quickly.
    We have schematics for most Fanuc controls and have repaired several boards with serial problems.
    It's better if we communicated by email: [email protected]
  1. Replies: 2
    Last Post: 12-04-2016, 06:08 AM
  2. Help -Mulitcam 84 plus Motherboard needed
    By solscenic in forum Multicam Machines
    Last Post: 07-22-2011, 08:37 PM
  3. Best contact for BPT motherboard repair
    By elsie215 in forum Bridgeport / Hardinge Mills
    Last Post: 07-06-2011, 04:36 AM
  4. Fanuc repair service needed in mid-south.
    By ncpapaul in forum Fanuc
    Last Post: 07-31-2009, 06:13 PM
