I have a few bolts that require 9/16-18 3B internal threads. I decided to try threading on the TL-1 lathe but something is not quite right.
Drilled bolts with 33/64 bit. I input the data such as minor diameter of .506 and major of .5625. After performing the thread function the threads will not accept a 9/16-18 bolt. I ran a hand tap through them and it was pretty tough being the bolts are so hard.
I have no idea what could be wrong. The thread insert is a dedicated insert for cutting 18 TPI.
I'm thinking maybe I did not set the "X" deep enough into the material. As soon as the insert touched the stock the X diameter measure was set.
Really appreciate any input with this!
Adam
