587,477 active members*
3,532 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > Mitsubishi Meldas 64 parameter backup problem
Hybrid View
    Nov 2016
    5
    Hello Everyone,
    I have Akira-SeikiCNC with Mi645 control. Just recently I lost servo battery power and had to replace them and reset zero orgins on all axis. Since main parameter backup uses the same kind of battery, I amafraid that it may fail soon too. I need to back up currentparameters before replacing battery. Unfortunately I can not sendanything from the control to my PC. I am getting E60 IOP ERR-2message as soon as I try to send anything to PC. I can input or DNC every program from my PC to the control, but can't get it to work the other direction. I tried pretty much every suggestion and the setting that work for other people but can't get a grip on this one.
    Can anyone with better knowledge of Meldas guide me through this problem?
    Thanks for every suggestion,
    Pete
    May 2014
    174
    Re: Mitsubishi Meldas 64 parameter backup problem
    Hello. I don´t think you need to back any of your machine data (parameters, etc) to change your battery. You just need to perform the battery change while your machine is powered on. I am sure there is a battery change procedure guideline somewhere, but it´s quite simple to follow. However, is not a bad idea at all to have all of your machine´s properly backed up. Because there would be other events where you will need to reload this functional archives.
    FLEX
    Sep 2017
    139
    The drive battery and NC battery arent same. You may cross check the battery voltage on NC unit to check if its okay or not. (3.6V). Also please let me know if its Meldas 60 series or 500 series to guide with the backup and battery replacement process
    Nov 2007
    22
    Quote Originally Posted by Pete_MP_Mold View Post
    Hello Everyone,
    Pete
    hello did you solve the problem of extracting parameters from your meldas? I have that same problem if you could help me.
    Jul 2018
    7
    Hello everone
    i have a cnc machine fulland 2005 model meldas 60 s. I load bacup from casset. But now mocro program gone and machine not change the tool. Could you please help me.
  1. Replies: 1
    Last Post: 12-26-2015, 03:39 PM
  2. Backup Mori Seiki NL2500 (Mitsubishi Meldas)
    By Krynio in forum Mori Seiki Software
    Last Post: 08-27-2015, 07:04 PM
  3. Dyna Myte/Mitsubishi Meldas 520M/Servo parameter adjust?
    By DynaMyte4400 in forum Dyna Mechtronics
    Last Post: 05-09-2014, 03:53 PM
  4. Feeler DT0 with Mitsubishi Meldas M50 parameter loss.
    By dpelivan in forum DNC Problems and Solutions
    Last Post: 01-10-2012, 10:48 PM
  5. Problem in mitsubishi meldas
    By mazman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-30-2009, 12:36 PM
