Hi all-
I am having an issue with NC programing and need some help.
I have Sheet Cam up and running. No problems there. kinda.
I am using a MD1 with an ultimax II controller.
When I program a move in conversational programming, and say I have the depth set at .75 inchs. When the program runs, the z axis display shows either .7500 or .7499
When I program in NC programing, and have the depth set to .75, then the g code line says flashes on the screen when it is running as g1 Z-.7500 The problem is the readout shows the part as .7492 or .7493
If while the G code is running a pocket and the depth is at .7500 and it is actually running at a depth of .7492, and I press the motion hold, then the Z axis moves to .7500
Is this some sort of programming parameter I need to change?
Why does it do it in NC and not Conversational programing?
Steve
