586,847 active members*
2,415 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > about to buy a chinese laser co2 machine - advice required
Page 1 of 3 123
Results 1 to 20 of 45
    Nov 2016
    19
    hi there,
    i am about to buy a chinese/ebay co2 laser engraver, im in the uk and my budget is £2000
    from what i can tell with my limited knowledge is it will engrave pretty much anything other than metals which it will mark with a spray treatment.
    i am a car trimmer and i primarily wanted it to work with leather and alcantara materials, but since looking at them im sure i would use it for much more
    some of the machines ive seen are rated at 60 watts and come with a rotary attachment (like and lathe chuck), others come with a better exhaust fan but no rotary thing, and t the top of my budget one comes with a proper water chiller and a rotary attachment - not the lathe chuck type but seems to be better as its not limited by the chuck size, this one is £2000 giv or take a few pounds.
    the trouble i see with the most expensive one is it doesnt support multi colours so i couldnt cut and engrave in the same job - i assume thats the only way i can do that (again limited knowledge)
    is the multi colour function to control the power/speed really needed or just a nice thing to have?
    any help and advice is going to be very helpful
    thanks
    Feb 2010
    155
    Re: about to buy a chinese laser co2 machine - advice required
    I highly recommend buying a machine with a true "DSP" controller like one from Ruida. The Ruida controller uses software called RDWorks/Laserworks. The Ruida control panel typically looks like this:
    RuiDa RDC6442G CO2 Laser Cutting Engraving DSP Controller System | eBay
    RDWorks/Laserworks lets you set different elements different colors/layers. Each color/layer can be set to either engrave or cut (at different powers/speed).
    There is a great new user group for users of the RDWorks/Laserworks software at rdworkslab dot com.
    If you are going to be using your laser for long periods of time (hours per day), or your ambient temperature is high, then I would highly recommend a chiller to extend the life of your laser tube. Different manufacturers have various recommendations, but generally the cooler you can keep the laser tube the longer the life. I keep my chiller at 19 degrees C for a 50W laser. Before I had a chiller the water temp would go up to 30C pretty quickly, especially during the summer, which is not good for long tube life. Beware, the cheaper chillers (e.g. the CW3000) are actually just radiators and can only get the water temperature down to ambient. Chillers like the CW5000 and the ones on Lightobject dot com are actual chillers (i.e. they contain refrigerant and keep the water at the temperature you set).
    I wouldn't worry about the rotary attachment unless you definitely have a use for it. I have never used mine. I am sure you could buy one separately if you do start to have a need for it.
    Jun 2014
    30
    Quote Originally Posted by jasongtr View Post
    hi there,
    thanks
    The below is my suggestion,hoping it can help you.
    1.For engraving on leather and alcantara,40W/60W both are ok.
    2.For the leather,alcantara materials is soft,so i think it should not need to use the rotary attachment.
    3.Need to use honeycomb platorm.
    4.Can you tell me what is the thickness of the leather,alcantara? If you cut,thickness is needed.
    5.What is the length and the width of the materials?
    6.Exhause fans ,all are machine have.
    7.For the chiller,usually 80W laser tube or bigger,we will suggest install.
    If you have any other question,please feel free to contact with me. My name is jenny ,i am in the fields nearly 8 years ,email is [email protected] , [email protected] . .
    Nov 2016
    19
    Quote Originally Posted by toyeacnc View Post
    thanks,i wasnt suggesting id need the rotary for the materials,maybe for glasses or bottles
    material will be 1.5mm max,
    i know they all have exhaust fans just some are the centrifugal type and are more powerful
    Nov 2016
    19
    Quote Originally Posted by robertk925 View Post
    thank you thats very helpful ill make sure mine has the colour separation capabilities
    Nov 2016
    19
    Feb 2010
    155
    Looks good, best of luck! Search for a user called SarbarMultimedia (Russ) on Youtube, he has a lot of really informative videos on a similar (smaller 50W like mine) laser cutter.
    Nov 2016
    19
    thanks will do, need to buy a proper water chiller i think and an ammeter, keep an eye on the laser stats so as not to allow it to run too hot and over power it shortening the life, from what ive read anywhere
    Feb 2010
    155
    Yes, definitely add an ammeter. It is pretty simple to hookup and gives you great info. to prevent overdriving your tube. I bought a 0-30mA ammeter for around US$7 and it works fine.
    Also, keep in mind that the 60W tube is probably over-rated. Mine was sold as a 50W laser, but based upon the diameter and length of the tube it is most likely a 40W tube at best.
    Nov 2016
    19
    think mine is an 80w, where do you connect the ammeter up to thats what i dont know, also what would you say is the max mA i should run my tube to?
    cheers
    Feb 2010
    155
    I followed these instructions (although I mounted it on the laser tube extension plate on the side of my machine).
    LensDigital - How to add ammeter to 50W Chinese laser cutter from eBay
    I don't know the max amperage for an 80W, but the safest thing to do is either go on the laser tube manufacturer's site (if you can figure out who actually made your tube) or go to lightobject dot com and look at the specs for a similarly powered tube. Lightobject's website tells me that for a true 80W tube the recommended amperage is 26mA (28mA max).
    Nov 2016
    19
    thanks, ive sinced found a Russ video about it, setting the thing up, beam setting i mean looks like not a lot of fun.... cant wait for that... not
    Aug 2016
    75
    If they send the same machine they show in those pictures (unfortunately, the Chinese often steal/repost pictures copied from others), I have the same machine. Based on conversations with other people who bought the same machine, the 80W tubes in these machines seem to be of better variety than those found in the 40 and 50 watt machines. Mine came with an Lasea/EFR F2 series tube that tested very close to 80w using Russ' Dohickey device.
    You definitely want to join and start reading the forums at RDWorks Lab - Forum
    "80 Watt” 700mm x 500mm Ke Hui 7050 Laser (Similar to the Red Sail)
    Nov 2016
    19
    Quote Originally Posted by vrc321 View Post
    thanks, hopefully it is going to be close to what i asked for, the way i looked at it was the higher the power i bought even though you shouldnt max it out (ammeter bought for immediate fitment when the machine arrives) the higher power i would have at my disposal.
    i will look into that forum
    thanks
    Jun 2014
    30
    You are welcome.For engraving on bottle and glass,i suggest the rolling type rotary attachment. For cutting 1.5mm thick leather,60W is ok,80W is better.Exhause fans,750W is ok for you?
    Nov 2016
    19
    i will get a rotary as i will be mark stainless steel tube, exhaust fan? no idea what power i have
    Jun 2014
    30
    OK.co2 laser tube only work on non-metal materials and the oxidized metal ( printed metal ) .By the way,you have bought the laser machine,right?
    Jenny (Ms) E:[email protected] / [email protected] Skype:toyeacnc ,www.toyeacnclaser.com, www.toyeacnclaser.com
    Nov 2016
    19
    a Co2 laser from everything i have read will mark stainless steel with the use of the prep spray, and yes i have bought one
    Feb 2010
    155
    Right, to mark Stainless Steel you need to use Cermark (better, more expensive) or Dry Moly (cheaper, more inconsistent results).
    Nov 2016
    19
    that Cermark better be good at £95 a can - hope it lasts a long time
Page 1 of 3 123
  1. Buying advice - Chinese laser
    By pvh5 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-11-2021, 06:59 AM
  2. Chinese laser which to choose metal sheet laser cutting machine
    By wklaserliu in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-02-2015, 03:22 AM
  3. 40w Chinese Laser will not turn on, any advice?
    By bazinga in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-26-2015, 10:46 PM
  4. Chinese CNC machine info required
    By ebygum1 in forum Chinese Machines
    Last Post: 06-03-2014, 09:22 PM
  5. Advice required for my next milling machine.
    By pigifly in forum Uncategorised MetalWorking Machines
    Last Post: 12-27-2004, 10:58 PM
