586,850 active members*
1,927 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > EC-400 are they a ok machine?
Results 1 to 11 of 11
    Dec 2004
    126
    Yes I know the ec-400 is not up there with Kiwa or mori but are they ok? I need one for light alum work and I`m tired of doing it on a VF with a 4th axis ... I played years ago with there older HS1 model and the pallet changer on them was full on junk. But the rest of the machine was ok for light work ... I have done a lot of reading on the ec-400 models but all the guys keep saying it buy a mori in that there made stronger ,,, but I`m looking at light alum cutting only.
    Dec 2008
    717
    Re: EC-400 are they a ok machine?
    Haven't worked on them but have known guys with them. They made them work just fine for what they needed. Probably the easiest step since you already know Haas.
    Is there a reason you think they won't work for you? (other than people that say buy a Mori) You already know what a Haas is capable of. I'd bet the EC is a more robust machine than your VF4. Haas verticals with lots of -Y- travel get pretty dang weak IMO...so you are likely going to be pleasantly surprised.
    Tim
    Dec 2004
    126
    90 % odf the machine is the same or VARY close to VF parts its mostly the pallet changer I was asking about ,,, the older HS1 machines were full on junk when it came to the pallet changer ,,, but it looks like haas changed the system on the newer EC machines ..
    Nov 2016
    We've had our machine for about 5-6 years.
    The pallet pool is fine.
    Aug 2005
    80
    Had ours for 5 years, palletpool version.
    chip evacuation from machining area is good but after that chips go everywhere except on the conveyor (we fixed this with sheetmetal,time and swearing).
    Coolant tank is to small and the water does not circulate back into the tank as quick at it should, so it needs to be topped up.
    Coolant lines are made of something similar to garden hose these bend at restrict coolant flow (we exchanged all of them and now have hydraulic hoses that dont bend)
    Coolant nozzles clog up quickly because of chips bypassing conveyor and head straight into the tank. (installed filter)
    Now for the really bad parts.
    The machine has tipped a palett over once while doing a pallet change, it did not fall into the machining area luckily.
    The palettpool has crashed into the setup station 3 times, 1 time when an operator was changing workpieces.
    Drawbar collar thingy (dont really know what tthe part was), cracked and needed replacing at 2000 machine hours.
    This destroyed spindle bearings, so spindle replacement at 2000 hours.
    Very light duty machine, much more so than i anticipated. Works for aluminium, steel was supposed to be run in this machine,
    but i leave that to our 25 year old mori that the haas was supposed to replace.
    Mar 2014
    133
    It will do what you want it to do, yes it's not a machine that cost 4x the amount of a mori. Although when something does break on a mori vs a Haas you better have patience for down time and a fat ass pocket book because it's going to cost you deeply.
    Quote Originally Posted by D.D.Machine View Post
    Are you still looking for a EC 400?
    Mar 2008
    638
    D.D.Machine, I have no information on the newer machines. Just wanted to agree with you on the older Haas horizontal machines. They seemed OK except for the pallet changer. What a POS. That crappy screw that came up to clamp the pallet was constantly jamming. They gave was a can of Anti-Seize to fix it! Lol. It didn't.
    However I have "heard" that the newer ones are far better. No personal experience. Good luck and tell us what you find if you go for it.
    I have a 2005 Haas EC 400 for sale?
    Mar 2014
    133
    The HS models were a motor/screw to clamp the drawbar. The EC series completely redesigned the clamping of pallets. Keep the inside of the machining area relatively clean and your coolant up to par then you should be fine. The EC series uses air clamping cylinders.
    Feb 2023
    Hi Mikel12,
    Would you happen to have a picture of your chip convyor
  1. Replies: 0
    Last Post: 04-23-2014, 09:39 AM
