586,753 active members*
7,226 visitors online*
Results 1 to 10 of 10
    May 2011
    180
    PCNC 1100 Motor shutdown
    I am starting to have issues with my PCNC 1100. Seems to be lacking power at times. Specifically:
    1/4" Carbide 3 flute mill doing slot clearing from Fusion 360.
    .375 DOC
    .0400 WOC
    5100 RPM
    32 in/min
    Chip load is .0021
    According to GWizard, should require .0918hp, which doesn't seem like a lot. The motor faults and shuts off. The fault light blinks then goes out.
    Q1: Anyone else see behavior like this?
    Q2: When the motor faults, the mill keeps running the program with the X/Y/Z which seems like a bad idea.
    I have also seen the motor bog down during a deep drilling operation with full retract using a 1/8" drill bit in aluminum. I am doing .0625 pecks and a full retract. That seems gutless to me.
    Kevin
    Jul 2015
    81
    Re: PCNC 1100 Motor shutdown
    Does it do that with new sharp tools?
    May 2011
    180
    Quote Originally Posted by oneineight View Post
    Unfortunately, yes! I thought of that to and grabbed out a brand new drill bit (screw length, decent quality) and carbide endmill never used before. I just switched to a Lakeshore Carbide variable flute and had better results by doing a .25 DOC. Still, this shouldn't be enough load to stop the machine, especially with a 1/8" twist drill bit.
    Jun 2014
    1780
    Quote Originally Posted by kevinro View Post
    .375 DOC
    .0400 WOC
    5100 RPM
    32 in/min
    Chip load is .0021
    Kevin
    Maybe check for loose power connections? It doesnt sound like too much load, spindle /motor bearings if the problem is intermittent.
    mike sr
    Mar 2015
    164
    Take a good look at the VFD in the control cabinet and the associated electrical connections. Verify VFD input power volts and use a clamp on amp meter to measure input current. There are some posts with pics related to VFD/spindle calibration that will help you get familiar with it.
    Aug 2013
    980
    Have you gone over the belt/tensioning? Have you tried changing belts/position?
    Quote Originally Posted by Uman View Post
    Jul 2015
    81
    Like popspipes and UMAN say, I would be checking for loose connections and input power voltage.
    It could be low voltage on just one leg of your power.
    Feb 2007
    1538
    And the spindle turns by hand freely?
    Keen
    Jul 2004
    1424
    If the VFD is shutting the motor down due to load, it should give you an "OVL.d" error on the VFD display.
    No errors on the VFD? Just the VFD shutting off completely? Not an overload condition. VFD doesn't power itself off in that condition.
    The spindle door microswitch will make that happen if it is a bit loose. Maybe it is vibrating under load. Also (as others suggested), a lose power connection to the VFD or lose control wiring on the VFD could do that.
    Does it sound like the motor is noggin down and slowing just before the trip?
    Tim
    Quote Originally Posted by tmarks11 View Post
    What year and model of machine? Motor door switch, you'll notice the motor slow because it's been tripped off by the switch. The axis does keep moving. My Series 2 did this a couple times til I changed the door switch latch. It was before the current latch design. As always check all the connections, I try to do this yearly. Just use a screwdriver to verify nothing is loosened.
    RAD. Yes those are my initials. Idea, design, build, use. It never ends.
    PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
  1. PCNC 1100 vs PCNC 770 (Is the 1100 worth it)
    By thunderdork in forum Tormach Personal CNC Mill
    Last Post: 09-21-2016, 08:43 PM
  2. Replies: 0
    Last Post: 05-24-2015, 06:14 AM
  3. PCNC 770 or 1100 Spindle Motor Specs?
    By techsavvy34 in forum Tormach Personal CNC Mill
    Last Post: 03-17-2015, 08:43 AM
  4. WTS: PCNC 1100
    By HLF Ordnance in forum Tormach Personal CNC Mill
    Last Post: 07-13-2012, 01:41 PM
  5. For those of you with a PCNC 1100
    Last Post: 01-02-2010, 12:51 AM
