Good morning everyone.
I'm really new in CNC machining and still trying to figure out how to create a G code. Been trying couple of times and nothing works for me.
I will be really appreciated if someone can help me in the begging by writing G code for a next part.
Short description:
I have 4 axis Chinese CNC machine which seems like working fine.
I'm cutting Bearing Bronze with 1/16 end mill 1/8 inch long bit.
Short explanation regarding the part.
I cut the case on my lathe which is cylinder 0.78" with cut inner diameter 0.66" and I need to mill those gaps 23 deg.
I showed it a little bit wrong but I need just 0.8" long cut with radius by the end (not flat as pictured).
Please help!!!
Thank you!
