Hey everyone, this is my first post here I've taken on a project to complete a 2 axis plasma table. Looking for some help on questions I can't find answers to.There is a lot of knowledge here on this forum appreciate all the help I can get. Thank you in advance.
I have 4 x 8 ft table currently I have 2 motors, the track, a plasma machine with torch.
My current issue is locating a driver to run the steppers I have. The GeckoG540 is what I'm eyeballing currently. Its a great all in one unit. The only problem I have encountered is the high inductance of my motor. Specs are as follows:
2.1 A/P
1.70 Ohm/P
8,0mH/P
269 oz-in
Serial # MP-2302-S-21
The Gecko can only handle max input voltage of 50v ( http://www.geckodrive.com/images/cms...8%20Manual.pdf )
"The power supply voltage is determinedby multiplying the square root of the motor’s inductance by 32, as in the example below for a 2mH rated motor:32 * (√2) = 45VDC"
Therefore my 8mH needs 90 volts! Which leads to the question..can I successfully run these motors on 50 volts without compromising too much stepping speed?
