587,043 active members*
3,193 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > speed control for perm mag dc motor
    1260
    A bit OT need a variable speed control for a 12V DC brush type permanent mag motor. Motor is rated at .4A no load to 3.4@ max 7200RPM Planning on using this on a 2 axis CNC controlled Ox/Acet burning table for manual torch height control. Any help much appreciated.
    If it works.....Don't fix it!
    Dec 2005
    3319
    There are a number of 'model train throttles' that will readily do what you want to do. However, to retain torque, you're probably better off with a PWM based throttle.
    Do a web search for an NE544 IC. THis is a servo driver IC that has been used to make PWM bidirectional speed controllers for a number of hobby uses over the years.
    If you're electronic literate, you can create a wein bridge oscillator to make a saw tooth generator with two stages of a 324 op amp. You can then feed the saw tooth into a comparator circuit made from the remainder of the 324 and drive a mosfet (IRFZ40 or 44). The whole circuit takes residence on half a business card.
  1. CNC Controlled Spindle motor speed control
    By gregmary in forum CNC Machine Related Electronics
    Last Post: 02-28-2009, 02:01 AM
  2. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  3. speed control for this motor
    By ZipSnipe in forum CNC Machine Related Electronics
    Last Post: 08-03-2006, 04:28 AM
  4. need speed control for single ph motor
    By FLUTE HEAD in forum CNC Machine Related Electronics
    Last Post: 10-06-2004, 04:35 PM
  5. AC Speed Control
    By georgebarr in forum CNC Machine Related Electronics
    Last Post: 01-07-2004, 02:33 AM
