586,320 active members*
3,848 visitors online*
    Feb 2012
    26
    GSK980MDc controller custom ladder help?
    HI all,
    I recently purchased a machine that was shipped with the very capable GSK980MDc controller.
    Thing is I use repeatable Z tooling similar to the TTS system for R8 spindles which allows me to premeasure and record the tool height offsets.
    Previously I was using Mach3 and this was not a problem
    With the GSK980MDc, to get this functionality, I will probably need to modify the PLC ladder that it runs in the background. It has functions in build for ATCs that I can purchase extra or make my own but that will have to wait.
    For the time being I am looking for help to do the following, remember I change the tools out by manually undoing the drawbar:
    When program call M6, the controller has been set to run program O9000 which I an code a macro for:
    1) Z axis go to reference position
    2) Machine display on screen "Change to tool Number ##"
    -Here I unscrew the draw bar and change the tool
    3) When cycle start button is pressed the CNC program resumes.
    I can write the macro to go to Z home and then execute an M00 wait but I cannot get the controller to ask for the next tool called by the T argument (e.g. T05). Setting the height after M6 executes is not an issue.
    If there is anyone versed in the use of the GSK ladder logic that is able to help, I would gladly pay.
    Kind regards
    George
    Feb 2012
    26
    Re: GSK980MDc controller custom ladder help?
    Nevermind,
    managed to figure it all out.
    If anyone needs help let me know, I am pretty clued up on the GSK ladder now.
    Regards
    Jan 2019
    I am looking for post processor for GSK 980 MDc.
    I use Gibbscam 2016 for 3-axis machining.
    Thank you in advance for your help.
    Apr 2012
    7
    Quote Originally Posted by komatias View Post
    Nevermind,
    Regards
    Hey Buddy,
    Can you help me with a ladder for GSK?
  1. Mitsubishi ladder for m50 controller AO
    By frith in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2021, 09:08 AM
  2. Custom controller
    By pmunizg in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-08-2016, 05:09 PM
  3. Help building a custom controller
    By Econdron in forum CNC Machine Related Electronics
    Last Post: 02-21-2014, 08:18 PM
  4. Custom controller software based on EMC
    By kolaloka in forum LinuxCNC (formerly EMC2)
    Last Post: 11-30-2011, 06:44 AM
  5. Custom build controller for CNC mill
    By jaydeep gajjar in forum CNC Machine Related Electronics
    Last Post: 10-15-2011, 07:50 PM
