586,459 active members*
3,538 visitors online*
Results 1 to 7 of 7
    Aug 2010
    5
    Ficep Beam Line Help
    We have a Ficep Beam line that our penchure the arm that pushes the steel is getting locked up. We have been on phone with Tech and they keep saying voltage problem but my shop checks and believes the voltage is ok. I have attached a picture of an error code below. Any ideas would be greatly appreciated. Also we are in the Texarkana TX area so if anyone has a reference for a good technician we might could use one.
    Attachment 335172
    Re: Ficep Beam Line Help
    Hi, I new here, if you ever have any problem with Ficep I can help you.
    By the way It seems that it is stock on the process where the machine it is loading and it is waiting for a sensor or a position.
    But any way, you may have fixed already.
    Have a good day!
    Do you have knowledge of a ficep Excalibur 12?
    Oct 2017
    Quote Originally Posted by eduardogonzz View Post
    Have a good day!
    I need some help with a ficep Gemini
    Error code ps 5381
    Have a good day!
    Maybe you can help me with this error. The drill will home just fine but when you try to run a program it stops and gives you this message then will not let you do anything.
    Found out that it was the nut that holds the hydraulic arm to the vise table had fallen off.
    Good Day Everybody. I have a ficep DBZ1001 the controller has blown, does anybody know where i could source another one. I have tried ficep and im not getting a response out of them. your assistance would be greatly appreciated.
  1. SDS/2 and Arianna for Ficep Drill/Torch Line
    By sippelsteelfab1 in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2014, 04:41 PM
  2. FNC files for letters (ficep)
    By speedingslug in forum Waterjet General Topics
    Last Post: 12-07-2011, 11:01 PM
  3. Ficep Operator NEEDED!
    By FicepCNC in forum Employment Opportunity
    Last Post: 10-05-2011, 05:04 PM
  4. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
