586,643 active members*
2,652 visitors online*
    Apr 2003
    1873
    Boot up issues
    TM-1 mill
    It's been giving me issues for some time but with repeated (10-15) re-set and Startup/restarts with usually (No Z Zero) it would finally boot up and function normally for the remainder of on time.
    Today was a first, went through dozens of startup procedures with it finally booting up an functioning normally although this was short lived and soon alarmed out after a few tool set up changes or axis movements.
    These are the multiple errors produced by these numerous re-starts, they came in no particular order or sequence.
    Z Zero Ret Mar too small
    Y Limit switch
    X Limit switch
    Z Limit switch
    No Zero Y
    No Zero X
    No Zero Z
    Seems quite unlikely all three switches went bad and/or causing trouble suddenly.
    I'm open for any ideas or suggestions.
    Feb 2010
    1184
    Re: Boot up issues
    Quote Originally Posted by Ken_Shea View Post
    TM-1 mill
    Y Limit switch
    X Limit switch
    Z Limit switch
    No Zero Y
    No Zero X
    No Zero Z
    A lot of times multiple random errors point to either a bad mocon PCB or a bad/weak low voltage power supply which feeds the mocon with +12, -12, & +5vdc.
    First confirm that your low voltage power is good. If that checks okay and with the power off to the machine, unplug and reconnect any connectors you find going to the mocon.
    Then see if the alarms go away.
    Let me know how you make out.
    Apr 2003
    1873
    Re: Boot up issues
    Voltage checked out with in specs, no -12v or +12v went to the mocon but pin voltage was perfect.
    Un-plugged/re-plugged every connector on the mocon board but no joy, it did finally boot, need to do some machining so will try and complete that before I shut it down to try booting again.
    Thanks much for the input, I'll let you know how the re-boot goes.
  1. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
  2. No Boot up HELP!!!
    By TurboBlazerX in forum Fadal
    Last Post: 05-04-2011, 02:41 PM
  3. Can not boot
    By wanchai101 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-06-2011, 06:54 AM
  4. BMC-20 No Boot
    By Rally in forum HURCO
    Last Post: 01-09-2011, 12:29 AM
  5. MB1 won't boot
    By daveelc in forum HURCO
    Last Post: 04-20-2007, 02:32 AM
