586,356 active members*
2,933 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Cutting thick steel plate
Results 1 to 20 of 26
    Oct 2006
    74
    I know this is probably a stupid question but here goes.
    I salvaged a large steel plate about a year ago. A 150lb or so behemoth 1" thick x 15" x 24". I have managed to take a few small pieces off but the problem is cutting the plate. I don't know if it is 1018 or a hot rolled steel. All I know is its a bear to cut the full 15" across and it eats thin cut-off and reciprocating saw blades.
    Tools I currently available to cut steel
    4 X 6 Bandsaw (kinda small but will easy cut the steel in smaller sizes)
    4 1/2" mini grinder (thin cut off blades)
    Sawsall (reciprocating saw)
    Circular saw (never used for cutting steel)
    Any suggestion or help would be appreciated to speed up my cutting operation. I would like to reduce the plate into manageable sizes. Please don't tell me to take it to the nearest shop. It took all my strength to just get it to mine.
    Woodenspoke
    Mar 2006
    759
    Try this:
    http://vansantent.com/Saws/evolution_saw.htm
    and check out their blades, you might have luck using one of them in your normal circular saw, but you will have to go sloooowww to prevent burning up the motor. The motors in the Evolution saws are pretty powerful and are designed to cut metal, whereas normal circular saws are not.
    You can also go to just about any home improvement store and buy simple metal cutting blades for a circular saw, but they won't last long.
    "If the women don't find you handsome, they should at least find you handy"
    -RedGreen show.
    Mar 2005
    1136
    while you can get away with circular sawing AL, its not going to work on steel, the saw won't go slow enough for the required cutting speeds (feet per minute) of say 80 for hss or 2-300 for carbide. same with the bandsaw unless its either for metal or you've geared it down for metal.
    the sawsall will cut it at low speed with a metal blade, but the thought of doing so probably falls under cruel and unusual punishment. Other than the unmentionable solution, get rid of and buy the size you need or beg borrow buy rent steal a torch and be done in minutes.
    Mar 2006
    759
    With the appropriate metal cutting blade (same material that your grinder and cutoff wheels are made of) from your home improvement center, you can cut steel with a circular saw. You just may not want to. It is a real PITA. The carbide blades are much better than those, although they may be designed to spin slower.
    I use a number of 4.5 inch cutoff wheels and grinding wheels spinning at 10000 + RPM on metal all the time. You know how messy those are, the one for the circular saw is even worse.
    Best solution? borrow a torch and get ready to be grinding for a while.
    -RedGreen show.
    Mar 2005
    1136
    massajames is right, I was thinking circular toothed saw blade, not abrasive cut of blade. still as he says, that's no picnic either
    Oct 2006
    74
    Thanks everyone
    I checked on the evolution blades and they will not fit my circular saw, which is a skill worm drive, the small blade mounts are 20mm and I need 5/8".
    Thinking:
    I don't want to attempt to use the Sawsall takes forever eats blades and I already tried. After using cutoff blades in the mini grinder I think the bigger cut-off blades would be worse, as Mcgyver said.
    I checked into other metal cutting blades after massajamesb post, because I liked that Idea. I found that Morse makes a blade called the Metal Devil and fits in a standard circular saw and is priced under $40.00 on amazon. Has anyone tried these blades? Plus its easier to clean up chips rather than dust.
    http://www.metaldevil.com/
    Another tool I own: I do have a (little used)sears twin bladed metal saw. Looks like a beefy mini grinder. The two blades spin in opposite directions (carbide blades). Makes a lot of noise lots of chips and its not easy to keep a straight line. The kerf is 1/4 " so it hogs out a lot of metal. It was a gift. If anyone has used this monster let me know what you think of using it on such a big piece of steel.
    Woodenspoke
    Mar 2006
    759
    I don't have any experience with the metal devil, but it looks like any other carbide tipped blade. I am not sure how they can advertise it to cut ferrous and nonferrous metals, as most non-ferrous metals generally clog up carbide cutting tools.
    for the money, try it. At 40 bucks, it might be worth it.
    -RedGreen show.
    Oct 2006
    74
    I checked out the videos on the Morse site. They use the evolution saw? If you watch the black pipe demo you can see it will take awhile to cut through heavy material.
    Anyway the evolution Blade maximum is 1/2" thickness? No indication on the morse blades. Even if it takes 10 minutes to cut through the piece its probably 25 plus minutes saved hacking through the plate if not more.
    Woodenspoke
    Aug 2005
    1622
    There in lies the problem with scrap yard metals. If you do not know what the material is or what application it was used in to garner a guess, cutting it with a torch could spell disaster for much if any secondary cutting operations. Torch cutting can harden the edge, making it non-cold-workable after. Welding it can also compromize the structure to a brittle state.
    For a $40 blade and a lot of headaches cutting it, not to mention risking the life span of your worm drive circular saw, I think I'd be buying a known grade in a more appropriate size.
    DC
    Jul 2006
    19
    I think the best way is to go at your local machine shop equiped with a cnc oxyfuel table. I'm the operator of one machine like this and we charge 45$/hour. It should be around that price every where. All you have to do is to put your desired parts in DXF formats and bring them with you at the shop. You will not have any special tools to buy and your cut will be precise at +- 0,010" with any shape.
    Oct 2006
    74
    I have successfully milled and Bandsaw sliced this steel Plate. This makes the material an unknown entity but usable. If I can cut it easily it will save me money, which in turn I can then spend on more tools to cut more stuff.
    I am always open to a better suggestion about cutting this plate thats why I posted this thread.
    "you never get anything for fee, there is always a hidden cost"
    Woodenspoke
    Jul 2006
    19
    The plate is usually 44w grade. The USA equivalent is A36. Thick plates 1" and above are normally 50w. It's near of the 1020 or less ...
    Mechanical Properties 44W/300W:
    Tensile: 65 to 85 ksi
    Yield: 44 ksi min
    Mechanical Properties 50W/350W:
    Tensile: 65 to 95 ksi
    Yield: 50 ksi min
    Mar 2006
    759
    DC[/QUOTE]
    I use a variety of metal forming tools every day, for the most part. Among them a planishing hammer, english wheel, slip roller, brake, etc. usually on nothing thicker than 16 gauge, which is cut with a shear anyway.
    Gawd help me if I have to cold work 1" thick steel!
    -RedGreen show.
    Aug 2005
    1622
    Cold working the material in its current condition has proven fine. Just test a piece by heating it better than red hot and let it air cool to see if the material flame hardens if you must resort to a hot cutting method. If it did harden without a test, then what would you do with it?
    My other point was in terms of ultimately gambling in spending more to cut the material while expending a blade and a saw, than what a smaller precut piece of material would cost. Even if that material too, came from a scrap yard. Possibly ending penny wise and pound foolish?
    Avoiding any heat induced cutting or bonding, you should be fine.
    DC
    Feb 2007
    79
    Plate
    I've used a plasma cutter on thinner stainless.....Has anyone used one on thicker mat'ls?....Just curious if one would cut 1" plate.
    Aug 2005
    1622
    Quote Originally Posted by massajamesb View Post
    If you cut metal by chipping it out with a saw, mill or drill, you are still cold working the material, are you not?
    I have even seen 3-6" plate cold worked by chip(bump) forming on Press Brakes. Better than 1" plates of Invar36 cold worked on gantry presses.
    BIG world-a-difference' between Machinists, sheetmetal or plate workers. Yet, if there is no heat applied to the metal, then the process falls into the same class of work as I know it. All be that moving it or removing it cold.
    Cold working the thick stuff is young mans work, but nothing impossible if you have the right equipment. Maybe it would help not to confuse cold working with cold forming though.
    DC
    This may sound extreme, but if you really want to cut it your self drill a long row of small holes about the thickness of an abrasive saw blade. Then saw the part, the holes will help keep the blade cool and straight! When drilling the holes, use brown pipe threading oil, available at any hardware store!
    You might want to rent a wet/dry skill saw, as a flood of water will also keep the abrasive blade cool!
    Either way you do this it will be a massive project!
    Good luck
    Eric
    Mar 2006
    759
    Quote Originally Posted by One of Many View Post
    DC
    I don't believe that I have ever had any reason to confuse the two,unless I was making a joke, such as I was. Sorry if I offended you, but I had a mental picture in my head of me trying to convince one of my shop underlings to try and shape some 1" steel on a sandbag with a shot hammer. Hence my post.
    I was simply saying I would never want to work with 1" thick steel in that application.I also have done my share of machine work, and you have a very valid point (more than one, actually). I do agree with you in full, make no mistake.
    Now, back to the subject at hand...
    -RedGreen show.
    Aug 2005
    1622
    No offense taken massajamesb.
    The first sentence was in response to your post. Just in case I gave the wrong impression in my post that created any confusion.
    The rest of my drivel was clarification to other readers that might not grasp the difference between the several forms of cold metal working terminology. Somewhat placed out of context by your humor, but not directed at you personally.
    DC
    Oct 2006
    74
    I don't know anyone with a torch. I believe drilling holes will take as long as hacking through it with a cutoff blade and I would be left with little arcs all over the piece.
    I assume no one actually checked the morse site, the blade is supposed to cut with little heat build up due to the grind of the blade, TCG 0 deg rake. Adding oil would just make a big mess all over my shop. Morse shows the blade cutting through 1/4 x 6" plate like it was a 2 x 4 stud.
    The worm drive circular saw is no run of the mill home depot consumer saw; it will most likely run long after the blade is turned to scrap. Hopefully the blade wont turn to scrap, but the saw is the least of my worries.
    I ordered the blade today . For $40 its worth a try. If it does work than it is a hell of a lot easier than torching, grinding or drilling through 1" steel. plus it can be used for other less demanding projects down the road. I'm going with massajamesb's suggestion because it looks do-able.
    Would I pick up a large piece of scrap steel again probably not.
    I will post my results in few days.
    Woodenspoke
  1. cutting long cut in 1/2 steel plate
    By ZipSnipe in forum MetalWork Discussion
    Last Post: 06-09-2006, 12:47 PM
  2. Cnc Machining 1/8 thick steel sheets
    By ccm in forum Uncategorised MetalWorking Machines
    Last Post: 10-28-2004, 08:47 PM
  3. Cutting 3/8 steel plate
    By BlueC in forum MetalWork Discussion
    Last Post: 05-22-2004, 04:06 AM
