587,006 active members*
3,225 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OKUMA OSP U100M HELP FOR SMALL MEMORY
Results 1 to 20 of 34
    Jan 2011
    32
    Hello everyone and thanks to all, I have bought an OKUMA OSP U100M machine, the memory is very small and the programs realized with CAD CAM software can not be loaded because they are a size too big for the memory machine. There are present RS232C socket and floppy, how do I know if there is DNC OPTION activated? How i configure the parameters for rs232 for connect a pc? I can start program directly from the floppy without loading them into memory for example with a string similar to "SPG,DD0:SC1.ISO" that I use to read programs directly from floppy on my edm charmille?
    Jun 2015
    4156
    Re: OKUMA OSP U100M HELP FOR SMALL MEMORY
    hi, there were similar threads lately, about file size issue ; this is all i can do :
    Quote Originally Posted by deadlykitten View Post
    on pselect is an option that allows "path" selection, only that it comes with restrictions as the path should be a "device name"
    i could acces only MD1 , AD0 , AD1, thus folders on "D drive", but nothing from outside this partition; also i tried US0, but it did not work
    also pselect comes with A ( normal file size ) , B ( big file size ) and S ( don't search soubroutines ) atributes, but i don't know if they work for you ..
    Quote Originally Posted by OkumaWiz View Post
    Depending on the control, you may be able to put in in with your system files and run from there. 7000 and u100 use MD0: before that it was BB0: on the 5000 series. They usually had much more memory available in the system files area. You can check it by doing FREE BB0: command. FREE BB0: ;C will show continuous available.
    Aug 2011
    420
    Solve is DNC-B option. Look at the OSP SOftware Management Data Card for the DNC-B option active or pasive.
    "Imagination is more important than knowledge."
    Jun 2015
    4156
    hy what means "1020 < 16320 < 49215 < 64515" ?
    Jan 2011
    32
    OK, but i don't know how change parameter or change mode a-b-c or view dnc setting if active, do you help me? thanks
    Aug 2011
    420
    is there OSP Software Management Data Card in the electrical cabinet of CNC
    Jun 2015
    4156
    Quote Originally Posted by kurmay View Post
    this management data card, ain't it also on cnc's hdd ?
    Quote Originally Posted by bigodinos View Post
    kurmay means to check if this option ( dnc-b ) is installed on your machine, by insepcting the "OSP Software Management Data Card"
    if it is there, than perhaps kurmay may help you continue ; so, do you have the "OSP Software Management Data Card" ?
    Aug 2011
    420
    I like playing with numbers
    Jun 2015
    4156
    maybe you hit 6 / 49 .... good luck with this, and pls don't celebrate alone
    Jun 2015
    4156
    is not my issue, but can this be done without the "Management Data Card" ?
    Dec 2008
    3122
    Yes....
    go to EDIT mode
    F8 (Extend), F8 (Extend).... should put you on the page with "PROTECT" as F1
    ( if you have the DNC option... it would be listed in the F3, F4 or F5 zones )
    If you don't have the option.... learn to utilise sub-routines & schedule programs
    Jan 2011
    32
    OK, i don't have, but i can load program in machine memory one for times with a pc connect with rs232?, i think a solution: format memory and load only one program and then cancel this and load another new
    Dec 2008
    3122
    I think the term is "INITIALIZE" the memory, "Format" will do other things
    - you can load a larger file into the control, than what can be selected to run
    If your program has jumps... ie sub or program calls then it has to be loaded as A or B method
    ;A method ..... loads program & reserve bubble memory for the subs and allow to background edit of the active program eg PS A.min ;A (PS = PSELECT, A.MIN=program to load, ;A= A method [note the semicolon before the A]
    ;B method ..... loads program & reserve bubble memory for the subs and NOT allow to background edit of the active eg PS A.min ;B (permits a longer program to be active]
    ;S method .... loads a program,.... DOES NOT allow any jumps, subs, etc......eg PS A.MIN ;S ( permits the largest possible program to be loaded into bubble memory....this is also limited, the maximum file size is still smaller than what ever file that could fit into the control)
    use a schedule program, & break a very large file into smaller files
    ie
    filename = RUN.SDF
    Code:
    N1
    PSELECT MD1:A.MIN ;S
    N2
    PSELECT MD1:B.MIN ;S
    N3
    PSELECT MD1:C.MIN ;S
    N4
    PSELECT MD1:D.MIN ;S
    END
    It may be possible to replace the MD1 with FD0 so that the search for the file is from the floppy drive instead of the machine control
    Jan 2011
    32
    thanks very very large.
    "t may be possible to replace the MD1 with FD0 so that the search for the file is from the floppy drive instead of the machine control" why??
    Dec 2008
    3122
    For example
    programs A,B,C,D are required for machining one part, but (together) they all won't fit into the machine control at the same time, but you could load them separately into the run buffer using the ";S" method
    using a schedule program automates the selecting of the next program to run, & then running it
    MD1: is the name of the drive for storing files.....like C: is to your PC
    .......... MD0: is the drive for the system files ( try typing DIR MD0: *.* <WRITE> & see what you get )....... do NOT play in this area..... you risk turning your machine into a boat anchor
    FD0: is the name of the floppy drive
    CN0: is the RS232 port
    TT: is the tape reader ( the old reel to reel punched tape reader, for those that still remember that era )
    Jan 2011
    32
    I DON'T UNDERSTAND WHERE I WRITE MD0
    Jun 2015
    4156
    I DON'T UNDERSTAND WHERE I WRITE ...
    should be an input bar/edit/line, after which you always press WRITE button, so to send the command to the cnc
    ... MD0
    such a briliant idea ! i am ashamed that I have not thought so : loading system files into the cnc ! with all those files types, something should definetly load
    i really can not imagine what would be the result; there was hardrware > operating system > cnc; now you load the system into the cnc ; this is a complete circle !!!
    definetly result is neither digital or mechanic; also, no way organic ... maybe a black hole or some kind of quantic-space-fizical-distorsion ? depends on chuck size
    ps : Superman wants you to be safe, and avoid MD0
    Jan 2011
    32
    You are great!!!
    I'M italian and write english is difficult for me
    [QUOTE=Superman;1941720]
    filename = RUN.SSB
    Code:
    N1
    N2
    N3
    N4
    END
    OK,
    what you said 'right , but I should still load the 4 programs in the machine memory that is large only 250k , so how do I do? thank you
    Jun 2015
    4156
    Jun 2015
    4156
    Quote Originally Posted by Superman View Post
    hello Superman, why did you said that is possible to load programs separately into the running buffer ? i don't understand this ...
    if i use :
    PSELECT a.min ; S
    PSELECT b.min ; S
    PSELECT c.min ; S > then this won't load all files ?
    and if i load them separately, as :
    PSELECT a.min ; S
    green button ( file loaded )
    PSELECT b.min ; S
    green button ( file loaded ) > at this moment, a.min gets erased ? so when programs are load one by one, actually, you load-run-load-run, not load-load-run-run ? did i get it ?
  1. Okuma OSP-U100M Spiral pocket milling
    By MoriSeikiNoob in forum Okuma
    Last Post: 10-29-2022, 03:56 PM
  2. OKUMA osp5000 memory isuues
    By bhatch327 in forum Okuma
    Last Post: 12-14-2020, 12:28 PM
  3. Okuma Howa VTM-100 lost memory!!
    By Thamaz in forum Okuma
    Last Post: 04-23-2015, 02:39 PM
  4. Okuma OSP U100M / U10M
    By bajivan in forum Okuma
    Last Post: 11-07-2014, 02:20 PM
  5. Okuma memory
    By billm01830 in forum Okuma
    Last Post: 01-08-2012, 07:39 AM
