Is it possible that decreasing the max speed of a spindle trough VFD and increase the torque at lower speeds?
My point is if I can use a 2.2kw chinese spindle as lathe spindle but the max speed I need is 2k RPM so I need to know if VFD drives are capable to play with speed/torque then the idea might be useful. So that there will not be any gearing needed.
The exact VFD I have is Huanyang 2.2kw.
Thanks in advance.
