Re: Help identifying part for G0704
Originally Posted by
JD2016
I didn't take the DRO for the quill apart. All I did was remove the DRO block from the spindle and rotate the quill handle to lower the quill/spindle assembly out the bottom of the head in accordance to the instructions. The mill has been CNC'd, so will this cause any problems. If any problems, can it be reassembled? Thanks.
If you pull the rule slide out of the DRO then this spring will come out.
Inner Vision Development Corp. - http://www.ivdc.com
Website Design & Development. Shopping Carts, SEO and more!
