440 not moving correctly after controller swap
Hey guys! I have one of the early 440s that had a firmware issue with the MX3660 controller. Tormach sent out a new one to swap out and I'm having some issue with the new one. Long story short, I was setup up a new piece to machine and things seemed strange. The G30 went to the wrong place, and everything just kinda seemed a little off. As it turns out, the axes aren't moving the correctly amount. I was zeroing my workpiece and it said the tip was 1" above the workpiece, but it clearly wasn't. So I used a 123 block and confirmed. When the machine says it moved 1", it's actually closer to 1.25". So, all the movements (x, y, and z) are about 25% off. Did anyone else have this issue? The first thing I thought of was microstepping, but that would be a factor of 2 right?
YouTube Channel: https://www.youtube.com/c/RobertCowanDIY
