587,008 active members*
3,295 visitors online*
Page 1 of 4 123
Results 1 to 20 of 73
    Jun 2006
    10
    Tria 7500 for Morbidelli Author 503
    Need urgent help for a Tria 7500 controller. Back-up batteri is gone dead, so the controller lost all data. Need help for the procedure to reinstall data. Got disk whith all data on (original) but need help step for step.(flame2)
    14
    I have the steps and the disk.. of the Tria-7500
    but my Machine it's an Author 504K
    And I don't know... if they are compatible......
    Jun 2006
    10
    Morbidelli A 503 STC
    Thank`s for the reaktion. It is working on a 503 STC, and we are now running again. The codes to be set is diffrent on the 2 maschines. For a Author 503 STC is it 1194121 space 1195457. I hope it can be usefull for others.
    Stoned.
    Dec 2008
    Morbidelli 504k
    I have a morbidelli 504k and I need PLC and wakeup code . Thanks
    Jun 2006
    10
    Hey Ronnieworks.
    I have got both code and procedure to load plc files agin. If i get your mail address i will send it to you as attached word file. You probartly forgooten to renew the back up battery, i tried it myself.
    Best regards: Stoned
    Dec 2008
    Morbidelli 504k
    Quote Originally Posted by stoned View Post
    Hey Ronnieworks.
    [email protected] Thanks
    Dec 2008
    Is your 504k with a twin pack and tool drawer if so could I get the plc and parametors and wake up code.
    Apr 2009
    Morbidelli 503
    Have codes and reload procedure for Author 504 and Author 503. email me at [email protected]
    Apr 2009
    NEED HELP with sizing on Morbidelli Author 503. Keep getting error 547 (Magazine Draw Back) when the machine DOES NOT have a tool magazine. [email protected]
    Oct 2009
    morbidelli author 504
    bonjour
    j'ai ma disquette parametre "HS" et doit les recharger sur la machine
    est ce que quelqu'un a ces parametres.
    merci
    Aug 2010
    Feb 2012
    Need Help! Tria 7500 Author 503 morbedelli with automatic tool exchange
    Need Help! Tria 7500 Author 503 morbedelli with automatic tool exchange:Can not find the proper start up discs ours seem to not be working ... contacted scm in the states with no luck tried calling UK with no reply yet. Can anyone help ? Thank you !!
    Jun 2011
    Morbidelli Author 503 (1995)
    Hi all.
    Is there anyone who can tell me if you can use G code X Y Z generatet from PC then transfered to the CNC by floppy disk?
    example would be nice
    I ask because right now we program directly on the CNC point to point and we use autocad to get the point to points and then punch them in manualy and some of the programs are very very long so it would be good to have a program where you can import the autocad drawing and generate the X Y Z and just copy it to a floppy disk and load it as a SUB program.
    Any ideas is helpful guys.
    Best regards
    Flemming
    14
    I do not understand your question, you mean to create a file and then copy it to CNC?
    Usually uses CAD/CAM Sofware.
    but for TRIA controls, you need a system that converts
    ASCII to PGM
    Some CAD/CAM Software to Programing TRIA 7xxx Controls are:
    ASPAN
    XILOG PLUS
    ALPHACAM
    I hope this information is helpful...
    Oct 2012
    Plz help me i have morbi 504 and i need help for load plc ste by step email [email protected]
    14
    I sent to you the Steps to load PLC data in AUTHO504
    By Email..
    Jul 2013
    Hola Baldo.
    Soy de Madrid (España), ¿Me podrías enviar por E-mail los pasos para cargar el programa de PLC en
    el AUTHOR 504. Muchas gracias. [email protected]
    Aug 2013
    Hi. Somebody have the user´s guide for program morbidelli 503, the list of g-codes available and I need access to the list of corrector x and y. thanks
    Julio
    14
    XILOG PLUS software is special for TRIA controls
    and has a programming guide, G00, G01, G02 etc.
    Aug 2013
    I have a morbidelli author 504. Replaced the battery and could not get it started again. Keep getting message that the plc is blocked. Can someone please help me or post me some instructions on how to get it going again.
Page 1 of 4 123
  1. morbidelli 504 tria 7500
    By rprman1 in forum Commercial CNC Wood Routers
    Last Post: 08-09-2023, 07:03 AM
  2. Tria 7500
    By num1040 in forum CNC Machining Centers
    Last Post: 11-30-2019, 03:12 PM
  3. Morbidelli Author 503 (1995) Tria 7500
    Last Post: 03-05-2014, 03:42 PM
  4. TRIA 7500 software missing
    By pablogvivo in forum Controller & Computer Solutions
    Last Post: 01-07-2014, 09:45 AM
  5. 'Errore Generico' Morbidelli tria 7500
    By fmorandini in forum Maintenance DIY Discussion
    Last Post: 11-03-2013, 06:48 PM
