586,648 active members*
2,380 visitors online*
Results 1 to 8 of 8
    Jun 2015
    3
    Sodick system files help
    We have 2 Sodick wire cutters 1 x A280 and 1 x 812 (BF275) . We have had a problem with the system files on the floppies now being unreadable on the machines. We do have the files on our windows PC however.
    The problem being is that no matter what I have tried, (formats etc) on blank disks , writing back to the new floppies is no problem and seem identical to the backed up files on the PC, the sodick just refuses to read them.User discs are not a problem
    The floppy drives on the Sodicks are not the problem. I have "been" there before and know they are fine. The problem lies probably? in the file structure written back to the new floppies. I have tried images and different utilities to make it work but can't.
    It might be something to do with the write speed for the drives.
    An obvious solution might be to make copies from the Sodick machine itself but if we can't start the machine and don't have a working disk to copy I'm screwed .
    It might be possible to run a disk from another Sodick but I think our files hold parameter info specifically to our machines. Another way is if someone who has been able to do this is to use our backed up system files and turn them into useful floppies.
    We would gladly pay for them.
    Another plan of attack is to change the drives for the usb converter which I think will work on the A280 with the fd1137d drives and use our PC files to the stick. The 812 is another story as the fd1135d drives should work with an HxC Floppy Emulator BUT
    needs a VFO board as well. I don't have a problem going that way in the future but for now I just want the damn things running so the floppy route is ok for now.
    :violin:
    Sep 2010
    72
    Re: Sodick system files help
    Not familiar with Sodick.
    How old are your machines?
    What format disc do they require?
    Some older machines will not read the "new" 1.44 MB floppy discs.
    Have you tried formatting them as 720 KB discs?
    Jun 2015
    3
    Quote Originally Posted by KilrB View Post
    Hi,thanks for reply,yes we have 720 format but nothing.Its
    Dos based but probably Japanese Dos
    Sep 2010
    72
    If you can still read the original floppies on your PC try this ...
    Instead of copying the files, image the diskette and then copy the image back to a new floppy.
    Jun 2015
    3
    Yeah we have done that also with the image back to new floppy but no go
    Jan 2022
    2
    Quote Originally Posted by jedi-nz View Post
    Good morning, I am in the same situation, the original diskette reads it to me, but I cannot copy them, I wanted to know what solution you gave to the machines, and if you were able to copy the loading diskettes. thank you
    Jan 2022
    2
    Someone was able to copy the boot disks of the sodick 530. My copies are no longer useful, I have the original diskettes but I don't want to spend them, and I have no way to copy them since I tried everything and it doesn't read them. Has anyone been able to copy the floppies? Do you know what format they take? Thanks you!!
    Hi
    I have the Original Floppy A500 disks, System, System 2.1, System 2.2 and USER disk. but, I need to create a image from the disk, I bought a USB floppy emulator and I want to use it, But I can't copy them, I tried with WinImage and floppy Imaging. the only disk that I made a Image is the USER DISK, because is a 720 KB format.
    How do you made an image of the system Disks?
  1. load System 3 in sodick A530D
    By hotrunner in forum EDM Discussion General Topics
    Last Post: 05-05-2021, 09:50 PM
  2. Sodick A3 system disk.
    By Namnp2007 in forum EDM Discussion General Topics
    Last Post: 03-03-2016, 01:24 AM
  3. SODICK A280 system error 12
    By Jones'r in forum EDM Discussion General Topics
    Last Post: 12-05-2015, 08:51 PM
  4. HELP SODICK A530D NOT REDY SYSTEM
    By intmaq in forum Waterjet General Topics
    Last Post: 10-17-2013, 03:15 AM
  5. System Error (12) Sodick Mark11 Silver
    By larswebb in forum EDM Discussion General Topics
    Last Post: 11-30-2012, 04:48 PM
