Re: looking for a decent torch height control Hypertherm max pro 200
The Max Pro 200 is a high frequency start. We have married it to several THCs. I would highly suggest you run something that may be more noise immune like an ethercut from CandCNC (Linux or Mach or stepper or servo). You will still need to ground the components correctly or your going to be starting over or fixing your electronics. The hard part about being in Canada is that you cannot get good noise immune electronics for a table build there. The Max Pro 200 uses an open collector for arc ok. You can either build the circuit to utilize the open collector or buy the CNC interface for it. Either or the Max Pro 200 is an awesome machine!!
Now featuring Plasmaland online
