586,555 active members*
3,477 visitors online*
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Feb 2009
    6028
    Re: Stinky Coolant
    Tramp oil is the biggest reason for stinky coolant. It's like covering up a dog turd with a plastic bag. That's why bubblers work, it breaks the surface tension. The other main reason I see coolant go bad is from how it's mixed, or not for that matter. Adding straight water is one of the biggest issues, you always want some mix, for the biocide in any half modern coolant. Another issue is how the coolant is mixed, always add concentrate to water, not water to the concentrate. Adding water to concentrate can cook off the biocide,, and can cause that jelly like separation.
    Sent from my A3-A20FHD using Tapatalk
  2. #22
    Jul 2016
    Re: Stinky Coolant
    Back to Waynec44's original question:
    For sure, coolants can get contaminated by bacteria. The bacteria loves the coolant, as the ingredients make great food. My shop has a weekly monitoring schedule. We'd test the ph, the concentration, and check for bacteria. We test on Fridays, read the results on Monday and treat the coolant with an anti-bacterial coolant additive if needed. This eliminates the stench that bacteria create and so keps the guys happy and free of skin rashes. We used Bug Check BF kits to test for bacteria. Manufacturer is Avalon Int'l. Corp.
  3. #23
    Feb 2018
    Re: Stinky Coolant
    Only coolant I've ever likes is blaser swisslube. Good stuff.
    One shop I worked in the owner bought this cheap Chinese stuff. It was gross. When the water evaporated over the weekend it turned to a solid clump. Almost like a big block of Crisco.
    Sent from my SM-G930W8 using Tapatalk
Page 2 of 2 12
  1. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  2. Looking for the right Coolant
    By JoshKY in forum Haas Mills
    Last Post: 08-12-2011, 01:06 AM
  3. stinky coolant
    By fourperf in forum Haas Mills
    Last Post: 10-12-2010, 12:06 AM
  4. Australian Gov't Gets Stinky
    By fizzissist in forum Environmental / Alternate Energy
    Last Post: 09-18-2010, 07:52 PM
  5. Coolant or No Coolant when turning....
    By Crashmaster in forum MetalWork Discussion
    Last Post: 05-20-2007, 07:20 AM
