586,326 active members*
4,766 visitors online*
    102
    7 Amp X 5 Mosfet Array
    SLA5046
    Just got a small handful of these ICs for FREE
    They appear to be an older IC but free parts is free parts.
    (I would have gotten more if I knew what they were
    at the time I just grabbed some because they looked
    interesting with that BIG heat sink die on the back)
    Mosfet Array, 5 Mosfets to each package
    3 ICs drive 4 five wire unipolar motors,
    and 3 Mosfets left over for other things
    Drain Current 7 Amps constant with
    about 5.5 Volts on the gate
    (if I’m reading the spec sheet right)
    possible 15 Amps pulsed
    Here is a link to the spec sheet I found
    http://www.allegromicro.com/skncatlg/array/sla5046.pdf
    EDIT:
    Looks Like SLA5024 might be a decent complement
    if you're running bi-polars, 4 Fets per package
    4 Amps constant, 8 Amps pulsed.
    http://www.allegromicro.com/skncatlg/array/sla5024.pdf
    Just thought I would point this one out to everyone.
    Mike_L
    When I was younger I thought I knew EVERYTHING,
    NOW, the older I get the more I find out I don’t know!
    Jul 2006
    103
    okay.
    my head hurts now.
  1. Mosfet Driver
    By tivoidethuong in forum CNC Machine Related Electronics
    Last Post: 01-19-2009, 04:20 AM
  2. LED array sequencer
    By MrWild in forum CNC Machine Related Electronics
    Last Post: 11-21-2006, 06:31 PM
  3. IR2184, HIP4080A, or other for mosfet driver?
    By originator in forum Stepper Motors / Drives
    Last Post: 11-03-2006, 04:31 AM
  4. MOSFET swaping
    By runnoahrun in forum CNC Machine Related Electronics
    Last Post: 01-21-2005, 12:41 AM
  5. Linear Array
    By hay171717 in forum G-Code Programing
    Last Post: 05-28-2004, 07:18 AM
