i like the motion of this, how fast do you think it is? especially at the end
http://video.google.com/videoplay?do...56142972031761
Hard to say but I wouldn't say more the 700ipm but its probably slower do to the size of the machine maybe 300ipm.
the g code says 10,000 units for feed. which if metric is about 393ipm so I would say thats fairly close.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
I doubt that's a real time video
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
interesting
a pnuematic vice on a 3 axis mill ,hmm the posibilities
makes me think of a mazak lathe i worked on with the robot loader
it looks fairly real time to me. But if you looke at the other video by the same group with the same machine cutting air, then you will see the feed rates going across the screen. F10000 if in millimeters is about 393ipm which isn't out of the realm of possibilities. And 393ipm also looks about right for the video, remembering that it is a small machine.
thanks
Michael T.
Hi all.
I'm building a CNC wood router machine , but i'm a little stuck with the mechanical things . I am trying to get the acme threaded lead screw and the stepper motors , but i dont know the specifications, which should i get first?? how to choose it's specification???
what should the speed of motion on each axis Be??
My machine is a 3 axis wood router , i'll be drilling MDF wood.
Y-axis : 4 feet long ,25 lbs horizantal movement
X-axis : 2.3 feet ,14 lbs horizantal
Z-axis : .6 feet ,11 lbs vertical
Help please ,thanks.
