586,878 active members*
4,108 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Haimer 3D Taster TTS Conversion Help
Results 1 to 16 of 16
    Jan 2016
    79
    I was able to pick up a new Haimer 3D Taster for cheap and jumped on the deal. It's the inch version with the 3/4 inch shank, model 80.360.00.IN. I was wondering if anyone has any experience or advise with the Tormach TTS conversion rings, either the press fit (Tormach P/N 32432) or epoxy versions (Tormach P/N 30675). I'm wondering what is the best way to convert the Haimer 3/4" shank to TTS so that I can use it for the Z-axis as well. Any advise or insight is appreciated. I'm looking forward to faster setups with the Haimer, but need to get past this hurdle.
    -Mike
    Mar 2011
    480
    You can get an er32 tts holder with a 3/4 inch collet.
    Apr 2013
    1788
    Re: Haimer 3D Taster TTS Conversion Help
    I would be concerned with possible damage to your probe using the press on TTS adapters. That said, I used one to convert an Iscar face mill. After heating with a hot air gun, the adapter ring just dropped on with almost no force required. I tried one of the glue on TTS adapter with very poor results -- the epoxy never completely set. Perhaps I didn't de-grease well enough or didn't mix the epoxy enough or the epoxy was old or...
    Does the shank easily detach from your Haimer? My metric one doesn't appear to but I haven't ever completely removed the centering screws at the back.
    Remember that the probes for the metric and imperial probes are different! Don't ask how I know.
    Jan 2016
    79
    Thanks for the feedback thus far. I considered the ER32 TTS holder, but am treating it as a back-up since I prefer not to add so much height to the probe. The TTS rings were my first option. Not sure if the shank detaches. I'm a bit phobic of dis-assembling the Haimer due to some bad experiences in the past with re-assembling precision tools. I'll try the press-fit ring with heating of the ring and an ice bath of the shank. If it doesn't go on with little/no force, I'll defer to the ER32 TTS holder.
    -Mike
    Apr 2013
    1788
    Don't make the mistake of getting the ring partially on and having it cool and shrink tight!
    Jun 2008
    1082
    Do you have it in-hand yet? Doing a Google image search for that model number there was a photo from slightly above the Taster. It looks like there's a SHCS in the middle of the shank. Perhaps unscrewing that would release the shank?
    I got coolant in my Haimer and took it apart. It's basically a dial test indicator inside. My attempted repair didn't go well (I made it worse and ended up throwing it away) but I bet if you confine your disassembly to the shank area you don't have much to worry about. YMMV
    Sep 2009
    624
    Quote Originally Posted by mikegiraud View Post
    -Mike
    Got the same model. I picked up some of the compression fit rings (MSC didn't have them when I looked, but Amazon has them, discussed here some threads back). Chucked up a ring, did the undercut, and then installed flush with the base. No pressure, no heating, no glue, removable. and it works fine on the TTS collet. Link to rings:
    https://www.amazon.com/Climax-Metal-...l+shaft+collar
    Jan 2016
    79
    Quote Originally Posted by GLCarlson View Post
    Thanks so much. This is what I was looking for.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Sep 2009
    624
    Credit another member of the forum who originally posted this (MFChief?). I just happened to see your request and passed along a good idea. There are a lot of them in this forum.
    Jun 2006
    3063
    I epoxied the TTS ring on my Haimer Taster about 5 years ago and it's held together fine ever since. I put a witness mark on my spindle and and always locate the Haimer face the same way with respect to that when I calibrate the Haimer or use it for setting work offsets in the hope of gaining a bit of repeatability.
    May 2016
    138
    Just an FYI for future searches, the shank does easily come off. Remove the SHCS bolt in the shank and loosen the 4-2mm set screws
    Apr 2013
    1788
    On my metric Haimer the 4 setscrews are M4 rather than M2. To eliminate the possibility of stripping the sockets on the setscrews I replaced them with SHCS.
    Nov 2009
    4415
    Thanks for this photo. I am installing a Haimer into a proprietary tool holder and needed to shorten that shank. It looks easy enough after seeing your pics.
    Quote Originally Posted by joshetect View Post
    A lazy man does it twice.
    Sep 2009
    624
    Yup. Get a bagful of rings from Amazon, do the undercuts, and you're set. My 3D Taster is set up like that.
    May 2016
    138
    Yeah that looks like a good plan. Wish I had seen it before
    Nov 2007
    2151
    Just a note and Tormach has a good video on this also. Check run out and set dial to zero every six months or so. I did my unit today and was surprised it had way more then normal run out. Hadn't checked it in a year or more.
  1. Haimer 3D Taster (probe) suddenly off .020" in x&y
    By WOTDesigns in forum MetalWork Discussion
    Last Post: 10-03-2017, 06:14 AM
  2. Haimer 3d Taster
    By slowtwitch in forum For Sale Only
    Last Post: 05-06-2016, 02:07 PM
  3. Haimer Taster clone
    By italia in forum Want To Buy...Need help!
    Last Post: 06-01-2015, 06:35 PM
  4. Haimer Taster Gauge
    By Artitus in forum CNC Machining Centers
    Last Post: 08-01-2014, 04:30 PM
