586,745 active members*
6,564 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > GrblGru: Free CAM and 3D-Simulation for mills and lathes
Page 36 of 38 263435363738
Results 701 to 720 of 758
  1. #701
    Jan 2024
    So tonight, I made my first steps on GBRLGRU..
    https://youtu.be/CoWiVhLOwac?si=CWtq-vkzBENKHZW_
    Now waiting for some more pieces to come so I can convert my mill to CNC...
  2. #702
    Feb 2024
    4
    Re: GrblGru: Free CAM and 3D-Simulation for mills and lathes
    Good Evening.
    I Have 90% made the Robot Arm and now I am sorting out the software/control. A have some experience with GRBL but none with GrblGru.
    I have imported the Step parts into Machine Manager. and they look OK to me. I thing its something to do with the Machine manager configuration and ME.
    I have selected ROBOT_ARM_5AXIS for the Machine Type. But I think it might be in the Z. Mapping section at the very bottom
    https://www.cnczone.com/forums/attac...1&d=1708641999
    I hope that is the correct method of posting a picture.
    Any advice would be nice.
    Thanks in advanced Antony.
  3. #703
    Feb 2024
    4
    Hi.
    Another Question.. Can I use Fusion360 to make the Step parts ? .. Maybe this is my issue I am having.
    Thanks Again.
  4. #704
    May 2016
    334
    Sorry, I haven't really understood the problem yet. You have created a new model for GrblGru and something is wrong.
    Can you please provide me with the STL files here and explain in detail what is not working ?
  5. #705
    Feb 2024
    4
    Thank you for your reply.
    Sorry for not giving you a good clear of the issues I am facing.
    I have got the first 3 Axis moving, Which are C,D and E.. Noticed that adjusting one Zeros the other. in picture "Actual work Position".
    And I am unable to adjust the settings in Rotation Axis. Picture "Unable to adjust"
    And the one that's most confusing is the Z Mapping . Not sure what Translation Axis is for ? or how to set the Axis assignments.
    Zip fil enclosed with Stl parts in. Hope this is Ok.
    Regards Antony.
  6. #706
    Dear GrblGru!
    GrblGru Lathe / my machine
    How do I get the y axis to be the rotation axis Y=F on the cnc shield of the arduino uno v3 or arduino nano v4
  7. #707
    May 2016
    334
    @AnyonyUK
    I have installed your model "aLFA" with minor changes in version V5.2.9.
    I recently changed the mapping again. The names in the simulation now always remain the same.
    Only everything that is sent to the controller via the interface is mapped.
    @kisjohnnie
    Sorry, I'm not a hardware / controller expert and I'm not familiar with the different shields.
  8. #708
    I was thinking of setting up something like this.
    https://docs.lightburnsoftware.com/Rotary-DSP.html
    Maybe add a straight cutter?
    https://youtube.com/watch?v=lpIQ-zYCA5Y&si=XGlI20rnn_bM5HU_
  9. #709
    Maybe there is an archive where older versions of GrblGru can be downloaded from?
  10. #710
    Re: GrblGru Troubleshooting
    Hi!
    I've recently built an MPCNC, installed Mega 5X on my board and GrblGru on my computer.
    I'm able to do the 2D simulations but not the 3D option. I load the STL, be it the ones that come with the program or one of my own design but once loaded it won't let me click on the object to locate or otherwise manage or modify it in any way shape or form.
    What should I do?
  11. #711
    Feb 2024
    4
    Thank you so Much. Working great.
    Regards AntonyUK
  12. #712
    Nov 2015
    Re: GrblGru lathe tool path ofset
    Dear all ,
    I would like to try grblgru, where can I find a wiring diagram for mega2560 ?....
  13. #713
    I am getting ready to try Grblgru. I am still awaiting the board I ordered.
    Can you give me an example of the file format you get in Grblgru, when you save probe points (your .wc file?)
  14. #714
    May 2016
    334
    Re: GRBLGRU...LO LONGER ABLE TO IMPORT 3D DXF. LATEST VERSION CONVERTS ALL TO 2D. WHY
    @kisjohnnie
    No sorry, I have only one old version V5.1.2 Please see my website
    @brunojbalestra
    Please refer to the help text on the main page, which you can display using the "?" button.
    See pic below
    @sargi
    Please google for "pinout mega2560"
    @Swirlygiver
    You can also start GrblGru without hardware and measure in simulation mode.
    You can then save the values and view them. Let me know if you need a special format for your application.
  15. #715
    Dear GrblGru!
    Here, how can I get the Y axis to continuously rotate the lathe chuck?
    https://youtu.be/6sA6cRqsOYw?si=7-0QxAoEOoyrQEAu
  16. #716
    May 2016
    334
    I don't know exactly what you want to do.
    The program for controlling the lathe (GrblGruLathe) cannot rotate the chuck continuously.
    At the time of development, there was no GRBL version for controlling a rotary axis.
    Only linear axes could be controlled. The Y-axis was therefore used for a different purpose.
    There are now many controller systems that can also control rotary axes.
    In the future I plan to to provide a corresponding machine model in the milling program (GrblGru), which can then be used to turn threads, for example.
  17. #717
    This is what I want to achieve with the grblgru lathe, so that it calculates how far the y axis must turn from the movement of the z axis, similar to threading
  18. #718
    May 2016
    334
    @kisjohnnie
    If you know a little bit about GCode you can do that possibly with the macros.
    Please take a look at this video:
    You can use it to control your specific process with just a few commands.
    https://www.youtube.com/watch?v=AwdbhN32g-4
  19. #719
    Thanks! One more question, does the GrblGru_Lathe get FluidNC control type support?
  20. #720
    May 2016
    334
    Yes, that should also work now. You can load FluidNC as a controller in the new version.
    But I don't have much experience yet because I only did it recently.
  1. Affordable CNC Mills and Lathes
    By cweber in forum Uncategorised MetalWorking Machines
    Last Post: 04-20-2013, 10:44 AM
  2. D&M Lathes, Mills, etc.
    By boatlover in forum Benchtop Machines
    Last Post: 04-25-2008, 02:39 AM
  3. Birmingham Mills and Lathes
    By smilenbseen in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2007, 01:19 AM
  4. Birmingham Mills and Lathes
    By smilenbseen in forum Vertical Mill, Lathe Project Log
    Last Post: 01-02-2007, 01:42 AM
  5. Darn near FREE LATHES!!!! - 2 lathes, gotta go NOW!
    By mxtras in forum Uncategorised MetalWorking Machines
    Last Post: 03-22-2006, 07:43 PM
