Re: EDM Resin Pump
If your system works the same as most, 5 is a higher level of conductive material. Tap water would be somewhere above 5, maybe 10 or 15, I don't know. But, as it is run through the resin, the contaminates are removed and water goes down to 4, 3, 2, 1 or whatever you need.
To make it go back up, you must add conductive material by adding tap water. The system is not designed to put contaminates back in. Don't know the size of you water system, but try adding a couple of gallon of tap water and see what the level is. Do not use reverse osmosis water has much of the contaminates have already been removed.
Good luck----------Mike
P.S.: The pump that runs water into you resin system will not run unless it is trying to "lower" the number. You have to raise it.
