Originally Posted by
SPEEDRE
After setting home zero, zero, zero do I have to set the material position as zero, zero, zero and is it called machine co ordinate?
My trials run in the opposite direction from what I desired. Also, if the axis run true, regarding positive negative direction,
why does move contrary to the code?.
Machine zero is where the machine is when ALL axis are homed
Work zero is the zero of the work-piece ( usually a corner of your stock material ) ( this is called up using the G54 G-code ) ( it stores the distance values form Machine zero to the Work-piece zero......it is not in your program, it may exist as the default )
( if G54 is X0,Y0,Z0 then your work origin IS the Machine zero, your CAD part should be placed according to this )
Code:
( Profile 1 )
( Mach2/3 Postprocessor )
N20G00G20G17G20G90G40G49G80 ( set rapid, check if m/c is set to inch, XY plane, check if inch...again, absolute, cancel cutter comp, cancel tool length, cancel canned cycle)
N30G70 ( not sure what G70 is ? )
N40T2M06 ( select T2, place it in the spindle)
N50G00G43Z0.7874H2 ( rapid, read H2 value, add to spindle length, goto Z0.787 above work zero)
N60S12000M03 (set rpm to 12000, start spindle CW)
N70G94 ( set feed per minute)
N80X0.0000Y0.0000F100.0 ( does your machine go to this position ?)
G20 should be by itself on line N10 ( also doesn't need to be stated twice on N20 )
Check the control to see if G54 is actually set & is being used
What values are in the G54 (work offset page) ?
Dose the machine travel to N80 ?.......is the material placed in the same position on the table, as it is in Arcsoft ( from your NC file, the cutter is moving in the X+, Y+ area , you seem to be only cutting a maximum of 1/8"" deep into the material )
