586,762 active members*
7,362 visitors online*
    Sep 2015
    7
    Question AutoLaser V2.0.8 - Password?
    Hi All,
    I have a x-700 from Redsail in China.
    All set up but being asked for a password when trying to connect to the laser via USB.
    Contacted Redsail but thought might be quicker here!
    Thank you!
    Sep 2015
    7
    Re: AutoLaser V2.0.8 - Password?
    To clarify it is asking for a password when I try and set "Machine Parameters"....I want to load the machine config file supplied with the laser.
    Thank you!
    Dec 2014
    187
    I use AutoLaser but don't have it linked to the Computer as I save everything to a USB Drive and run it from there so never tried setting things up from the computer. When it asks for a Password, try 0000 , 1234 etc as a lot of times its a standard password.
    Sep 2015
    7
    Hi Ken,
    Good suggestions! =)
    The password is tz0001.
    It is not needed to connect via USB but it is needed to adjust the "Machine parameters"....I thought this might be needed by the AutoLaser software but it seems it is just the config the machine.
    My file (loaded via USB stick) is acting weird. It seems to flip the image sometimes but not others.
  1. AutoLaser not working properly
    By dwagar in forum Redsail Laser
    Last Post: 10-14-2016, 07:47 AM
  2. AutoLaser 2.1.7 - Reverse before Saving
    By KenR60 in forum Laser Control Software
    Last Post: 06-22-2016, 10:36 PM
  3. Unable to open AI files at AutoLaser
    By Frankie0808 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-15-2016, 08:25 AM
  4. FYI - RD Works, AutoLaser, LaserWorks program
    By tauscnc in forum Laser Control Software
    Last Post: 11-20-2015, 05:46 PM
  5. AutoLaser 2.0.8
    By thefitz in forum Laser Control Software
    Last Post: 06-22-2015, 05:37 AM
