586,525 active members*
3,151 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > How to do eccentric turning in FeatureCam?
Results 1 to 8 of 8
    Aug 2012
    54
    Hi All,
    Has any one know how to do it??
    Thank You
    Jul 2010
    369
    Re: How to do eccentric turning in FeatureCam?
    miki2432
    This will get you what you want.
    Just remove the G97 "S"CODE AND M13.
    I just do a mill path with a tool as wide as the nose radius of my turning tool and there you go!
    CHANGE THE OPTIONS TO SPIRAL TO GET A CONSTANT Z STEP OVER
    Good Luck~!:cheers:
    Jul 2010
    369
    USE THIS FILE....
    Attached Files Attached Files
    Aug 2012
    54
    Thanks Perfect Circle :cheers:
    Can you provide the .NC file for this operation?
    Thanks!!
    Jul 2010
    369
    Quote Originally Posted by FlorinMBV View Post
    Thanks!!
    A bit of the code.
    There is a ton...
    N0101 (TOOL=01 PASS=01)
    ( MILLING: BEM .031 4F-ROTARY X )
    N80 G19 G20 G40 G54 G80 G98
    N85 M45
    N90 G0 T0101
    N100 G0 C10.501
    N105 G0 X11.0 Z0.0157 M8
    N110 G1 X8.4692 F200.0
    N115 X8.4648
    N120 X8.4599
    N125 X8.4598 Z0.0156
    N130 X8.4596 H1.496 F2709.1
    N135 X8.4572 Z0.0155 H1.641 F2709.8
    N140 X8.4541 H1.641 F2710.7
    N145 X8.451 Z0.0154 H1.532 F2711.6
    Sep 2019
    I need encentric progaram cnc swiss lathe tsugami how we can process
    Sep 2019
    I need progaram 4mm rod bar please help me any both need progaram
  1. Okuma eccentric turning (camshaft)
    By Lary in forum Okuma
    Last Post: 09-26-2023, 11:21 AM
  2. Programming for Eccentric Turning...
    By Jashley73 in forum Okuma
    Last Post: 07-20-2018, 09:14 PM
  3. Replies: 6
    Last Post: 09-08-2016, 03:29 PM
  4. eccentric
    By hongjianming in forum CNC Swiss Screw Machines
    Last Post: 01-05-2011, 06:37 PM
  5. Eccentric Turning on LB 300
    By jimmyjolly in forum Okuma
    Last Post: 03-17-2010, 05:40 PM
